003R - Only 4 mic pre\'s!
I have a digi003rack and I'm getting to the point now where I need more than the 4 mic pre's on my interface in order to track drums the way I want to. 1.) What connectors should I use in order to take advantage of the 4 TRS inputs? (I need top quality reproduction from my mics) 2.) Whats the best option for a mic pre with at least 4 XLR inputs and 4 line outputs? (budget oriented of course). 3.) Should I just get an analog console? Any information that can answer any of these three questions for me would be greatly appreciated. Thanks and happy holidays to all.
Re: 003R - Only 4 mic pre\'s!
You could get external preamps to output line level +4 and input that as +4 using Analog 5-8. Additionally, the TOSLink provides 8 ADAT channels (if you can find a bank of preamps capable of supporting TOSLink), so technically speaking you can run up to 16 channels of analog input.
It's all a matter of being resourceful There's a lot that can done with just an LE rig if you put your mind to it, think sideways, and open to different workflow methods! |
JM11... nice screen name...
How to get 18 inputs with an 001/002/002r/003/003r? (You can thank spkguitar for this helpful PT Newbie site...) |
a small console will generally get you the most bang for the buck. a used mackie can be a great quality/cost value. plus, mixers are just handy things to have in a studio. if you want four great pres for 600-800, google up a sytek. you can find a bank of 8 pretty good pres that will output to lightpipe (TOSlink) for a little cheaper. you can get a behringer unit for, I think, 200 bucks. behringer is not bang for the buck, generally. you'll throw it away in a few years.
http://soundofthatday.com |
Pick up two of these:
http://www.mercenaryaudio.com/fmrrnmp.html Use balanced 1/4" TRS cables to connect them to your 003R line inputs. This will give you four channels of solid mic preamps that you won't outgrow.
Joshua L. Decatur, AL |
Thanks a lot for helping me out everyone. I've only had this system for a few months and it's awesome to be able to learn from people who have more experience.
I have the 002r but got it modded by BLA...of course thst doesn't change the fact that I only have 4 pre's on the rack; but I have a Macie D8B so I actually use the analog in to that & then digitally assign tracks thru my DA'88's which are running straight into the 8 analog ins on the 002...Of course since the mod my gain staging is crazy now so I actually go in with no compression, eq, or anything...11 mics on drums, (I also use the Adat i/o's thru the mackie & I have a JoeMeek TwinQ which gives me another 2 i/o's Coaxial for the 18...I know that may sound like i'm not helping ur situation but if u really read it I think it will....
I'm thinking that I might go with the ART MPA Gold. Two of them that is. They're in my price range around 600 combined and I get tube warmth. If anyone has had any experience with these preamp i would appreciate any input you can give. Thanks
I will get punched in the nose for this one... but:
Have you actually tried what kind of drum sound you might get by simply connecting some good dynamic mikes in the 003R line inputs at -10 ? At least the signal chain is short. This is obviously "wrong" and your impedances are wrecked and the level will be low in most cases. But I have done this a few times in a pinch with a 002R. Use the micpres for OH and BD / Sn , for example. Or just room mikes, experiment. My results have been quite usable in a "rock band plays live" -type of mix. Worked for 4x12 guitar cabimets,too. Try different mics. You can always get the low level up. And with this "mixed-impedance-way" there´s not as much need for hi / low cuts.
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Mic pre's: MBox 2 VS cheap Behringer pre's VS M-Audio Firewire 410 (Mp3 samples) | DanielPinho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-18-2009 04:14 PM |
003r BROKEN MIC PRE's for input 3 & 4???? PLEASE help!!!!! | ninja pro-tools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-26-2008 12:06 AM |
003r BROKEN MIC PRE's for input 3 & 4???? PLEASE help!!!!! | ninja pro-tools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-08-2008 07:40 PM |
Lining outboard pre's through the Digirack pre's | falsemetal666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-16-2006 04:53 PM |
digi pre's Vs Mackie pre's - anyone? | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-01-2001 04:49 AM |
