Old 01-22-2020, 02:54 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default Updated everything - NOW P.T Crashes / protools wont load my projects
Hi Guys, I've been traveling and suffered some personal hard times over the past three years.
Now I've got my gear out out storage finally (that all worked fine before)
.., and now if I try to load my old ProTools projects (and earlier unfinished original works in progress) ...,
- I get a crash ( ie; application quit unexpectedly message window) in pro tools on startup, but otherwise, if I say create a new project pro tools opens fine
Note :
- i updated my OS from Sierra up to Mojave
- I updated protools from 3 years ago to PT2019.6.0
- I updated all my plugins and VI's and their libraries, including Arturia Toontrack, Native
instruments and all the Avid extras etc, making sure nothing was left out.
I am only on the cheaper perpetual plan and not the avid support plan (rant alert; even though you buy their product and its not working you should get support no matter what), so all I can do is send them a crash report but as far as support from them ..., well no support otherwise.
any ideas guys?
also ;
im on a mac pro late 2013 (the trashcan)
mbox pro (latest updates)
pro tools projects on a separate PCIe drive (note I also copied these to my desktop )
backup drives net the same crash results also
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's
Old 01-22-2020, 09:52 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Updated everything - NOW P.T Crashes / protools wont load my projects
Hi, Besides all the normal troubleshooting like trashing preferences, optimizing OS, etc., my first guess would be a plugin causing the crashes. Maybe it's trying to load an older incompatible plugin? Have you tried opening the sessions with all plugins disabled? If that's the problem, you just need to figure out which plugins are the problem ones.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-22-2020, 10:33 PM
moshuajusic moshuajusic is offline
I don't know when you did this, but they do give you a limited amount of time for live support when you purchase an upgrade, even without purchasing separate support. Or maybe they give you 1 free support case. I forget which. Would be worth double checking your account and/or trying to reach them anyway.
Old 01-23-2020, 02:01 AM
Stephen Bond's Avatar
Trashed prefs? First thing to try in this situation.
Also, do you have access to a later version? if so, install it! The recent ones are more stable on my system.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 01-23-2020, 02:43 AM
Ale Ale is offline
Yes its a plugin causing this.
I had the similar this week.
It turned out that an EQ was the problem.
Doing all import tricks did not help.
It ended in installing an OLD version of the eq und all was good.
Try to import track by track to narrow down and see what plug couses it.
Or remove some used plugs and see if the session loads.
Put one by one back and see what happens.
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 01-23-2020, 04:32 PM
Cheers for the advice guys i will try all.
just to refresh my memory ...,
Question 1; how do I trash protools version19.6.0 again (on Mac Pro running Mojave) ?
.., as youtube vids etc only show;go to - library/preferences/ then an avid folder?
- note; i do not have this avid folder at all in that location? .., so where do i find it and what do i delete?
Question 2; can I open pro tools without the plugins and instruments loading ?
.., or do I need to uninstall protools , followed by uninstalling all plugins and V.I's
.., and then reinstall protools ?
.., as i want to add plugins one at a time if possible to search for the culprit?
Old 01-23-2020, 10:48 PM
cwsand's Avatar
Use this guide to delete Pro Tools Preferences: Mac Guide - macOS 10.14 Mojave Optimizations and Troubleshooting
From the Reference Guide:
Opening a Session or Project with Plug-Ins Deactivated
To open a Pro Tools session with all plug-ins set to inactive:
1 In Pro Tools, choose File > Open Session.
2 In the Open Session dialog, locate and select the session you want.
3 Shift-click Open.
Good luck!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-24-2020, 12:18 AM
lae777 lae777 is offline
Q1 - The easiest way to trash your preferences with OS X is to use Pete Gates application which can be found at http://petegates.com/pg-pt-prefs.html
Q2 - Just move all your plugins from the plugins folder found at Mac HD/Library/Application Support/Avid/Audio/Plug-ins to the Plug-Ins (Un used) folder, at the same location.
When you relaunch Pro Tools it will only load the core Avid plugins.
See if your problem is solved. If it is, you will know that it is probably a third party plug in causing the issue.
Quit Pro Tools.
You can then move your third party plugins one at a time, or in groups, back into the Plug-Ins folder, relaunch Pro Tools, check whether the problem has returned, and repeat until you find the culprit.
No need to re install Pro Tools.
Opening the session with plug ins inactive will still load them at launch, so it won't help you find which one is causing problems.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
Old 01-24-2020, 01:07 AM
cwsand's Avatar
Sounds like he's getting the crash when opening the session, which is why I suggested opening the session with plugins disabled. Your way will work too, just a little more complicated.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-24-2020, 01:21 AM
hi Guys , im starting to have some luck.
I downloaded to pro tools prefs app and trashed prefs, then moved all plugs / everything out of the aax folder and into the unused folder .
I am now addig plugins one by one .
Hey Guys, does anyone know what happened to XPAND!
.., its gone and i can't see where it is to download from anywhere. ve spent 4 hours on the net and zero luck (ive downloaded reinstalled the AIR package twice and its no longer amongst that package
many old projects used xpand and many had complex settings, and i need it back badly
Protools 9.0.3 Wont Load.. audio1420 macOS 2 06-13-2011 10:27 AM
Protools wont load Drakui Pro Tools M-Powered (Win) 2 04-04-2011 03:27 PM
protools wont load any of the vst !!PLEASE HELP!! millz85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-01-2010 01:30 PM
M Powered Academic Version wont load and crashes my Mac PokerDude422 Pro Tools M-Powered (Mac) 0 09-08-2007 05:47 PM
PROTOOLS WONT LOAD? RoyaltyOnline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-14-2007 10:29 PM
