Pro Tools Crashes during "Restoring Tracks" portion of startup
iMac 7 4GB Memory
Digi 003 Eleven Rack Mac OSX 10.5.8 Pro Tools 8.04 Dig 003 is the Master clock and ElevenRack is slaved to Digi 003 via SPDIF. Audio output to monitors originates at the Digi 003. ElevenRack is only used as an input device and passes its I/O to the Digi 003 via SPDIF cables Problem: When loading a specific song, when Pro Tools gets to the "Restoring Tracks" startup message, Pro Tools crashes. Other Songs load fine and I can create a song with no issues. I suspect that there is some I/O issue between the ElevenRack and the Digi 003. Is there some way I can delete the I/O setup and then rebuild the I/O paths after the song has loaded? |
Re: Pro Tools Crashes during "Restoring Tracks" portion of startup
It might be that the session itself is corrupt. You could try to import the tracks to a new session, a few at a time. Maybe you can narrow it down to a track.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Lenovo T61 T9300 Core 2 Duo 2.5ghz 4GB DDR2 2 1TB FreeAgent Xtreme External Drives SIIG FireWire Express Card Windows 7 Ultimate X64 Pro Tools 8.0.4 LE Digi003 Rack || PreSonus D8 || ART MPA Gold || ART PRO VLA II || Ensoniq DP/2 M-Audio Axiom 49 || Behringer BCF2000 Yamaha HS50Ms Bands: Captain Starr || stereoINs Drums: 1 || 2 || 3 Guitars: 1 || 2 || 3 |
If I were you guys, I would be looking for an offending plugin.
First, why not try: pull out all non-digi plugins, try to open your un-openable sessions.
Doesn't make a difference - if it was a bad plugin, it wouldn't load at all when importing the session data. But, for me, it loads when importing session data, but not the entire session.
This means it could be a plugin in my opinion.
ok I'll try the Shift-Open trick.
definitely not a plugin.
I'm consistently getting this issue with a session as well and it's driving me crazy. Things will be going smoothly, then pro tools freezes, I get the beach ball, session crashes, need to hard reboot.
Then after rebooting (twice - once hard reboot, then one regular) if I try to open session is crashed on the session is corrupt and I can never use that file again. Thank god for session file backups. I then use most recent backup and restore session from there and save as restored versions. Any figure out what could be causing this unfortunate bug?
MBP M1 Max | 64 GB | 4TB | macOS Monterey Version 12.7.4 [Legacy] Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Catalina (10.15.7) w/ Pro Tools Ultimate 2020.12 [Legacy System] Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O |
fixed??
Pro Tools Crashes on Startup During "Setting Up I/O Paths" | ChrisIQ | Pro Tools 10 | 3 | 08-24-2013 05:27 PM |
Popping sound during "Restoring Tracks" | notr2d2 | macOS | 0 | 08-06-2013 10:24 AM |
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" | georgelegeriii | Pro Tools TDM Systems (Mac) | 0 | 11-19-2012 12:14 PM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
Structure "restoring tracks activating insert" for ever | houser | Pro Tools TDM Systems (Mac) | 0 | 05-20-2009 02:35 AM |
