Can\'t write trim automation from control surface
I'm having trouble trying to write trim automation from the C24! I select trim mode, make the adjustment and when i unselect trim mode it just reverts to as it was! if i make tha changes with the mouse its fine?? If i put the track into auto record and trim then it writes auto as normal and ignores the trim! if i try to use the write automation to all command it does nothing! Is it now broke?(along with edit groups) or am i doing something wrong!! used to be a really quick and easy feature. Chris
Re: Can\'t write trim automation from control surface
Can you give a specific step by step description?
Trim mode has changed for 7.2, but I assure you, it works. Note in the Mixing prefs pane there are 3 "trim coalesce" choices. However, it almost sounds like you are in read/trim mode, rather than write, latch, or touch/trim mode. In "read/trim" if you exit trim mode you lose the offset you had. "Read trim" allows a new functionality where you can preview the trim level for as long as you want, and then either ditch it or manually "coalesce trim" on that track. Danny Caccavo Product Manager Digidesign |
Trim mode from 002 control surface? | SirLexelot | Pro Tools 9 | 1 | 11-16-2010 12:05 AM |
volume automation and a control surface (BCF2000) | Chief Pronto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-08-2009 12:34 AM |
[Bug] Trim or Nudge Destroying Trailing Auto Breakpoints Written using Write-To | jeremiahmoore | Post - Surround - Video | 3 | 11-21-2008 12:29 PM |
Mackie Control-Can you write Automation In PT? | flymax | Pro Tools TDM Systems (Mac) | 3 | 01-24-2006 05:02 PM |
Decent, Inexpensive Control Surface -Niche Automation Station | LA_Sprawl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-07-2002 12:24 AM |
