Old 09-04-2003, 10:37 AM
jpoprock jpoprock is offline
Default Pitch control w/ LE?
I didn't see anything in the manual about this... so i'm assuming you can have any pitch control with LE. is this true? Like, slow the tape down a bit to do a high harmony, then bring it back up to "0". I'm screwed if I can't do this. HA! Thanks!
Jason
Leo 10.5.7
PTLE 7.4.2, 002r, Micro
iMac G5 2.33ghz Core Duo Intel
OWC External FW HDD
http://www.soundclick.com/jasonsheroan
Old 09-04-2003, 11:00 AM
pk_hat pk_hat is offline
Default Re: Pitch control w/ LE?
I'm not sure I understand what you're trying to do. There's a pitch plugin which allows you to alter the pitch of an audio file offline, not in realtime. There's a pitchbend wheel on most kb controllers, and there's pitching a sample up and down a keyboard when using a sampler. What exactlty do you need, can you elaborate?
www.myspace.com/krou
Old 09-04-2003, 11:41 AM
On my old ADAT, I could slow the pitch of my music bed down a little so that it was not only playing back slower, but the pitch was lower. Then I'd record my high harmony (if it was too hard to sing at std pitch). Then I'd bring the pitch back to "0" and my harmony would sound as it would have if I had been able to sing that high in the first place. You can't get too wacky w/ your pitch though because if you do, your high harmony will sound sorta "chipmunk" in it's tone. But it's saved my butt a million times. OR, if I was having problems playing a guitar solo part, I could slow the tape down, play it, then bring the tape back up to speed and my passage would sound as though I played it in real time. Does this make sense?
Thanks!
jason
Leo 10.5.7
OWC External FW HDD
Old 09-04-2003, 11:46 AM
I see.
As far as I know, you can record at half-speed in ProTools. I guess it's the closest function to what you described.
Old 09-04-2003, 03:47 PM
Homebelly Homebelly is offline
There is a pitch shift pluggin in the AUDIOSUITE list,,you could try singing your harmony in unison,then play arround with the pitch shift plug,,I used to use it to create strange FX with my guitar or drum loops,,it worked quit well for that,but it did leave a few after-affects that might not sound to good on a vocale,,depending on how radical your pitch-shifting might be,,or how prominant you place them in the mix,,it might just be okay,,if it gets close to what you are after then you could look into any of the more expencive options,PITCH AND TIME,AUTOTUNE or PITCH DOCTOR are the ones that come to mind,,
Old 09-04-2003, 03:53 PM
To VSO the word clock in LE you ned to feed the SPDIF or ADAT input with a varisped clock source... an ADAT (or MDM) with VSO capability works well for this application.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Does ProTools LE have a Pitch control I can use? Jimibrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-20-2010 04:30 PM
8 pitch control jimskiwax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-04-2008 03:37 PM
Pitch Control Plug-In popedcollarpro VENUE Live Sound Systems 1 03-10-2007 04:42 PM
Pitch Control Plug-In popedcollarpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-10-2007 12:19 PM
Mbox: Pitch Control? Not In Manual? krsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-14-2005 09:55 PM
