PT 8LE help!!
I have m-audio fast track-powered essentials PT8 box and software. I'm wanting to know if PT 8LE will work with my m-audio fast track as a interface without having to buy a M box or any other hardware interface. I did not know where to post this question. Thanks
Re: PT 8LE help!!
Not going to work. LE only works with Digidesign-branded hardware(Mbox2, Mbox3, 002 or 003). You could probably buy a used 002r for $100, and if LE is all you have, that would be my recommendation. While its not considered a "great" sounding interface, it works fine, and you CAN bypass the "less than stellar" inputs and outputs with some external units and the digital IO if you need to improve the audio.
BTW, since I have used(and owned) both the 002 and the FastTrack(with M-Powered Pro Tools), I would move away from the FT.
