No OLED channel info on Mix after 3.7
Since installing Eucon 3.7 when I start up the MC Mix oled strip is off and
I can only get it back by removing the surface and then re-instating it in Eucon. Anyone else seeing that? Is there a fix for this please?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Re: No LED channel info on Mix after 3.7
Also why are all the record button lights on now?
That's pretty distracting.
Same here, have to power off MC mix, re power it on and then restart Eucon apps ... odd behavior
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11. |
Read the guide about the new automation write feedback feature...I suspect its that.
I'm not sure what is meant by this ?
It means that when you start Eucon it sees the MC Control but not the Mix ... you have to power off the MC Mix and power it on again and then restart Eucon for it to work properly. Also banking is still not working as it did in earlier versions
Thanks Eddie I found the preference to revert back to the old record light behavior.
With the MC Mix, when I start up the surface with Eucon 3.7 running, the faders will come up to match the session, but the information strip at the top of the surface is black, ie switched off, no channel names etc. I have to manually remove the surface in Eucon and let it find it again for the channel names to appear. This didn't happen with the previous version of Eucon. My MC mix firmware says it is up to date. Any ideas? Thanks
OK Simon and Cheesehead? I'll have to wait until Monday before I'm in front of Mix's but will try a few versions and see if I can reproduce it.
We changed banking to bank by the number of available strips if you have tracks locked and not by 8. |
Thanks Eddie, look forward to hearing your results
no TRIM MODE info on oled displays? | cebolao | Avid S1, S3, Dock and Control App | 15 | 09-22-2017 07:59 PM |
Artist Mix Oled not working in one channel | Giba | Artist Series | 1 | 07-12-2017 06:52 PM |
OLED info time out ? | priorytools | Avid S4/S6 | 3 | 11-21-2015 09:48 PM |
Midi Channel Info | Sparky1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-15-2011 03:39 PM |
mc mix second channel 's OLED missing ! | klyg | Artist Series | 2 | 10-10-2011 10:14 AM |
