A quick way to remove plugs from a track?
Couldn't find it in the manual--
I want some key combination with a click that will remove plug assignments from a track. Similar to making it inactive or bypassing it. Is there such a thing? "Remove Plug From Track"! Or even a way to clear all plugs from a track at once. thanks!
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Re: A quick way to remove plugs from a track?
Hold down option and select no insert, the whole row will go to no inserts.
MacBook Pro M1 Max • 64 GB RAM • macOS Monterey 12.2 • PT 2021.12 |
That will remove all plugins on all tracks from the corresponding slot, I think the OP wants all 5 slots from a single track removed, and I don't know a way to do that. However, you could duplicate the track and have a copy with no inserts and alternate between the two quite easily.
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
Yeah no way to do that function.
Thanks--and if anybody else has ideas, please keep 'en coming!
One feature that I miss since PT4 is to be able to bypass all plugins in one track with one click so I could compare processed and no processed signals...
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
the duplicate track (sans plugs) is probably the best solution, but I wanted to add that throughout my day I do make plugs inactive a lot. (ctrl/apple/click on plug). This seems to be the fastest (even when I have a few inserts on a track, as I just hold the ctrl/apple and keep clicking). Not a perfect solution, but it helps.
... but does it help the chorus? |
How to remove Avid plugs | woof | AAX Plug-ins | 6 | 02-17-2014 10:08 PM |
Best way to remove TDM plugs? | lampmusic | Pro Tools HDX & HD Native Systems (Mac) | 1 | 03-23-2012 10:07 AM |
I Can't remove HTDM plugs! | a2zproductions | Pro Tools TDM Systems (Win) | 7 | 05-28-2006 02:57 PM |
How do you remove HTDM plugs? | a2zproductions | Pro Tools TDM Systems (Win) | 2 | 11-20-2005 08:29 PM |
how do you resedit/remove plugs? | abbyin3d | Pro Tools TDM Systems (Mac) | 2 | 12-31-1999 08:25 AM |
