Re: Local Storage on Pt First
Don't hold your breath if First gets people buy PT it works as intended
In my case it did and i don‘t regret 🙂
Hi Netmania,
Would the below workaround be an idea? I did some basic tests only... Worth giving it a try. Store the complete Pro Tools folder (that is including subfolders and files) on a different drive and use mklink to make a shortcut as if the files were still in your Documents\Pro Tools folder. OS: Windows 10 Pro x64, build 1909. Pro Tools First 2019.6. ASIO4ALL v2.14 FIRST. I moved the complete Pro Tools folder and its contents (around 1 GByte in my case) from Documents\ to a folder on a preferred data drive (E:\bin\). I assured that the Documents folder did not contain any Pro Tools folders or files anymore. The new folder is then now E:\bin\Pro Tools SECOND. I opened CMD in Administrator Mode and entered this mklink symbolic link command (the quotes are needed because of the spaces in the folder names): mklink /d "C:\Users\USERNAME\Documents\Pro Tools" "E:\bin\Pro Tools" CMD should then come back with: symbolic link created for C:\Users\USERNAME\Documents\Pro Tools <<===>> E:\bin\Pro Tools In the Documents\ folder I found the by mklink generated folder Pro Tools again but then as a shortcut. I started Pro Tools First 2019.6 and it worked OK. BTW. I do not sync too much to the AVID cloud at the moment since due to COVID-19 the servers over there are a bit crowdy... (untick the green Backup to Cloud bullet). Good luck Harry |
Hi Harry,
thanks for your solution. Since I shifted to Pro Tools Full there is no need for me to go that route. By the way - meanwhile I bought a mbox2 for dirt cheap and got Pro Tools 8 LE full version without subscription. It makes fun to see how easy things can go - plug in my Mbox, fire up Pro Tools, rename and move folders etc. everything works. No Cloud, no internet, very, very fast and stable. I payed 100 Quitt for Mac mini, Mbox 2, Logic express 9 and Pro Tools 7 and 8 LE. Pro Tools First is 8 months after release of Catalina not compatible, that's a shame in my opinion for AVID - since they loose a lot of starters that buy a new MacBook Air 2020, MacBook Pro 13 2020, MacBook Pro 16 2019, Mac mini 2020, and Mac Pro 2019. No one with a Focusrite, M-Audio or many other Audiointerfaces who wants to Try out Pro Tools First is able to start. Sorry Harry, bit off topic Have a nice day and stay safe. |
iLok USB 2 Not Showing In Local | Puddles98 | macOS | 1 | 12-12-2015 04:46 AM |
Local i/o From S3 | amesiandy | Avid S1, S3, Dock and Control App | 2 | 11-18-2014 10:44 PM |
Online or local backup ? | chrisdee | General Discussion | 5 | 03-01-2013 04:39 PM |
Simple Idea for a Local Workgroup Storage Server? | spicyitaliano | Pro Tools TDM Systems (Mac) | 10 | 09-28-2007 06:12 PM |
Sending Local Off | Dirk Reinking | MIDI | 0 | 09-08-2007 08:19 AM |
