Old 11-21-2003, 03:56 PM
broodley broodley is offline
Default Digi002 Rack Firmware update w/o internet?
Hello,
I've got a Digi002 Rack running ProTools 6.2.2 on a dual 2 GhZ G5, when starting ProTools it says the 002 firmware needs to be updated (we have 1.08, it says we need 1.11), but our Macs are not connected to the Internet. Is there any other way to recieve the firmware updates? I can't find them anywhere on Digi's site. I found one firmware update under support downloads, but it's only version 1.05a for Digi002 mixer.
thanks,
brad
Old 11-21-2003, 04:01 PM
makarushka makarushka is offline
Default Re: Digi002 Rack Firmware update w/o internet?
That update is in the file "Digi 002", in the "Controllers" folder. You do not need Internet for this update. The very fact that Pro Tools prompts you for the update means that it has found a file that contains a newer version than there currently is in the 002R. Just click OK and let it do its thing, it should work... After it is done (could take minutes), quit Pro Tools, power cycle your 002R, and the next time you run PT you should not be presented with the same dialog again. Hope this helps!
Old 11-21-2003, 04:25 PM
jeffro's Avatar
jeffro jeffro is offline
Thanks to makarushka for the help!
BTW, this will be changed in the future from "download" to "update" to avoid confusion.
linkedin
Firmware Update HELP. My 003 Rack will not update Firmware. New003RackUser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-17-2007 09:01 AM
Digi002 Firmware update issue _ron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-03-2005 03:51 PM
DIGI002 firmware update and click plugin gigi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-14-2004 09:14 AM
Digi002 Firmware update jimll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2003 02:07 PM
002 rack firmware update killed my rack and OS X bandgear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-01-2003 08:25 PM
