Old 11-09-2017, 12:36 PM
maz_records maz_records is offline
Default Apogee Rosetta 800 With HD Cards
Hello Everybody,
I have a couple of questions to upgrade my Studio.
I use MAC OS on my control room and mbox 3 pro with RME ADI 4 Converter, Running on ProTools HD-10 , and now there is a deal in front of me to have (Apogee Rosetta 800 with 1 core card and 1 accel card PCIE "HD1") .
So if i bought them "Are they Going to be compatible with ProTools 10 HD?"
and "If so, How many Track they will support on the DSP?"
"and what the type of plugins that they will support and hw many?"
The last question "if want to hear normal sounds on my MAC like a song from Finder or youtube , is this will be a problem?"
Thanx A Lot and hope to have an Effective reply
Old 11-09-2017, 02:37 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Apogee Rosetta 800 With HD Cards
If the Apogee has X-HD card installed, it will show up as Digidesign/Avid interface to PTHD
Janne
Old 11-09-2017, 02:54 PM
Pro Tools TDM cards support... TDM plugins. You can run those as well as RTAS and AAX-Native (32-bit) in Pro Tools 10 if you add TDM card(s).
The main reason for going to TDM would be to monitor through plugins at low-latency.
The main reason for going to Digilink interfaces (which you could also do with HDX or HD Native) is high IO counts.
If those things are not issues for you so would I would not consider doing this.
You need to spend time understanding the minimum system requirements for the TDM cards and things like voice count limits on the TDM cards—read the Pro Tools 10 Reference Guide. All your questions, and more you did not know to ask yet are in that document.
You cannot aggregate a Digilink interface with non-DigiLink interfaces so you would only have the Rosetta to work with unless you added another DigiLink interface.
Old 11-09-2017, 03:06 PM
It is not clear how you are using the MBox 3 Pro and RME ADI-4, but with the Rosetta 800 You cannot add to the 8 channels with ADAT in. You get to choose between analog in or ADAT in, and presumably you are buying the Rosetta for its c
analog conversion...
Old 11-09-2017, 04:31 PM
So u mean that if i had the X-HD Apogee card it will act as an Avid Interface.. and in this case i'll not need to get the core and accel or i'll add them with the X-HD card ?
Old 11-09-2017, 05:14 PM
??? The X-HD card goes in the Rosetta 800 and gives it DigiLink connectivity. The Core card in your computer provides DigiLink connectivity. You connect the interface and core card/computer with a DigiLink cable. The Accel card provides more DSP processing beyond what is already on the core card. There is no DSP processing done except in those cards.
The TDM cards will not operate without a DigiLink interface connected (like the Rosetta with X-HD card).
What actual problem or limit with your current system are you trying to solve?
If you go to a TDM DSP system you cannot upgrade beyond Pro Tools 10, will never be able to run 64-bit Pro Tools. Will never be able to run current Mac OS versions or run on any current or future Mac.
An accel and core card is actually a HD2, not sure why it is being called a HD1. Make sure you know/see this works as it’s easy to get a dud card.
Old 11-09-2017, 09:25 PM
Samanthas Dream Samanthas Dream is online now
How much are they asking for the TDM cards and the Rosetta?
FA: Apogee Rosetta 800 joepopp Buy & Sell 0 09-19-2013 07:20 AM
New in the box Apogee Rosetta 200 192 AD/DA postman56 Buy & Sell 4 06-03-2013 02:54 PM
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED jrhager84 Buy & Sell 5 03-11-2013 01:25 AM
96/io to apogee Rosetta 800????????? MASTERLINKSTUDIOS Pro Tools TDM Systems (Mac) 7 09-23-2009 08:25 AM
How would you use an apogee rosetta within 001? cane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2001 07:08 PM
