Automation questions - Trim and Snapshots
Having read the bit in the manual about snapshop automation, I was wondering if there was a quicker way to "Store" the snapshot info and "fire" it with the click of button or something, sort of like how one does it on a Euphonix. Can you store the snap with a location? The method of alighting on an are of automation that you want to use and writing it on an area you want it in is fine, but to store this in a floating window or something would be handy.
Another automation question about trimming: I'm used to the GML paradigm for trimming, i.e., being able to select faders and enter how far up or down I want them to trim (in stop mode, of course) then OK'ing it and it's done. Is the closest method in ProTools to doing this to select volume data in the Edit window and trim with the trim tool, or would you trim in real time and "write to all"? I prefer to trim in stop mode, not during PB. |
Re: Automation questions - Trim and Snapshots
I think you'll find the trimming in stop method very intuitive once you get used to iy
Paonic, the answer to your second question is that all of your trimming techniques will work...sort of.
The easiest way to trim, in my opinion, is to do it "offline" on the volume graph. I haven't tried discontiguous selection in PT5 to see if you can do this to multiple areas at once, but it might work. You can't enter volume offsets numerically in the Mix window (I don't think...it's never occurred to me to try), but you can move a fader - or set of grouped faders - and look at the level numbers. That works in real time or when stopped. |
Automation Snapshots | RecRoom | Post - Surround - Video | 10 | 11-28-2016 10:48 AM |
Automation snapshots? what are they? how to? | postprosound | Post - Surround - Video | 4 | 04-10-2007 08:43 AM |
Automation Playlists & Session Snapshots | Mount Royal | Pro Tools TDM Systems (Mac) | 10 | 09-04-2006 06:04 AM |
Notion: Automation Playlists & Session Snapshots | Mount Royal | Pro Tools TDM Systems (Mac) | 0 | 08-15-2006 06:19 AM |
plugin automation snapshots possible? | Mark Dann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-12-2002 06:02 AM |
