Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-14-2020, 09:06 AM
stargazer stargazer is offline
Default USB ports and MacPro5,1
I have some problems with my Macpro5,1 and USB peripherals.
I connect an iLok, a VSL key, an Apple Keyboard and a bluetooth wireless mouse receiver, each on a port of it’s own (4 of the 5 available ports), to my MacPro5,1.
Even if those peripherals don’t consume a lot of power the MP loses contact with some of them from time to time.
If I, for example, try to add/connect some (self-powered) hard drive and/or a usb midi controller, it makes Pro Tools ask for the iLok (or VE Pro ask for the VSL key), even if I use a powered USB hub.
Is this a known issue?
I’m not sure a new, better powered, USB-hub would help me since there seems to be enough power available on the USB buses.
And I don’t necessarily need more speed, but I want to be able to keep more devices connected at once without problems.
Any advice?
Thoughts on USB PCIe-cards?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 06-16-2020, 02:48 PM
bartosz idzi bartosz idzi is offline
Default Re: USB ports and MacPro5,1
The powered USB hubs do help. I use company called Plugable. You can find them used. I have two usb hubs connected - one older USB 2.0, and one newer, with even stronger power supply USB 3.0 model. I also use two 10m extender cables (passive) to connect both hubs to the machine room. They mostly work fine. (btw, i do not endorse cheap usb-Ethernet adapters, they are crap)
The way i did this is with system information utility - (apple ->this mac->system report) I connected two hubs via 10m cables to the two different usb controllers as indicated by system information utility, then experimented with other dongles.
Initially i had everything on the hubs, but having some issues i moved the iLok and Syncrosoft dongles to the front ports of the Mac Pro 2009. That is pretty stable for me, works fine.
The things i have connected to the usb3 hub:
- mouse, keyboard, command 8, shuttlexpress, logitech web camera, usb media card reader
usb2 hub gets:
- emagic mt4, printer,maschine mikro, korg nanocontrol2
I have some free ports on the hubs. But found out by experimenting that dongles work better plugged directly to the front of the mac.
Hope that helps!
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Old 06-17-2020, 01:38 AM
Originally Posted by bartosz idzi View Post
Thanks a lot, bartosz idzi!
After some trial and error I also found out my dongles work better directly in a port of their own, especially the Steinberg/Vienna key.
It’s now plugged in directly to one of the three ports on the back of the Mac.
Hopefully this will be stable, so I don’t have to ”lose” one of the PCIe slots to an USB PCIe card.
Old 06-17-2020, 01:55 AM
on the Mac Pro 2009 (and up to 2012, I believe) the two back ports counting from the right are usb2. The leftmost port is usb1. Do not waste usb2 ports for dongles :) This is where the hubs are supposed to be. Check it out in system information - >usb.
Old 06-17-2020, 06:23 AM
I checked today, and actually my 10m extender is active:
https://allegro.pl/oferta/aktywny-pr...10m-8969837898
If you want maximal reliability, i think this is the ticket:
https://www.unitek-products.com/prod...xtension-cable
Old 06-17-2020, 09:12 AM
Actually all five USB ports on 2009 and 2012 MacPro's are USB 2.0 according to everymac.com https://everymac.com/systems/apple/m...ex-macpro.html
Jack
QAPLA!
Old 06-17-2020, 11:25 AM
Not here, according to my system report: (and believe me, i checked with my devices)
Old 06-17-2020, 01:49 PM
Then you have something odd going on as I doubt everymac.com is wrong
Jack
QAPLA!
RX580 + HDX on a Cheesgrater Macpro5.1 Stephen Webster Pro Tools HDX & HD Native Systems (Mac) 6 03-28-2020 04:42 PM
HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD? alonper Pro Tools HDX & HD Native Systems (Mac) 16 06-26-2018 04:47 PM
Mid 2012 MacPro5.1 6core 3.33 for PT12 ? SD70 Pro Tools 12 2 05-21-2018 04:04 AM
Mac G5 ports WRX07 General Discussion 3 02-21-2006 09:11 AM
Not enough USB ports! saltobello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-18-2005 10:14 AM
