Old 10-05-2016, 03:51 PM
BMXnotFIX BMXnotFIX is offline
Default Trouble with Digi 002r Standalone ASIO Drivers
So I primarily use PT12 but I also have Ableton 9 and Reaper that I would like to use my existing setup with. I've downloaded the latest Core Audio drivers (8.04 I believe) but I can't get either program to recognize my 002. In Reaper I can see the ASIO Digidesign Driver FW002 but it doesn't display any I/0 and says "Failed loading ASIO driver" and in Ableton I can see the driver as well but the same result when I try to use it. I've tried legacy drivers as well but to no avail. I know it's a driver issue since it's consistent between third party programs but Pro Tools works flawlessly. I've scoured the internet trying to figure this out to no avail. Any input?
Old 10-05-2016, 07:18 PM
Default Re: Trouble with Digi 002r Standalone ASIO Drivers
I would try the latest 003r driver(9.xx I think) as the 2 units are very similar.
Old 10-06-2016, 04:14 AM
zolko
Guest
Posts: n/a
I would not, cause the latest does not contain ASIO part of the driver.
Check this thread out: http://duc.avid.com/showthread.php?t=319361
Old 10-07-2016, 06:57 PM
Well, there's always ASIO4ALL
Old 10-09-2016, 01:17 PM
Finally found a driver that worked.
http://secure.digidesign.com/service...&localeCode=en
Old 10-10-2016, 02:55 AM
zolko
Guest
Posts: n/a
Great! Which one?
Digi 002R stand alone ASIO drivers? DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 38 06-28-2010 07:26 AM
002R ASIO drivers causing issues?! DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 04-29-2010 11:22 AM
Standalone ASIO drivers for Win7 x64 kenzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-21-2009 07:57 AM
Cubase not recognizing 002r ASIO drivers JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-15-2006 02:52 PM
Problems with ASIO drivers, Cubase SX3 with 002r fog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-12-2005 07:53 PM
