Buzzing From One Guitar Only
Never had this problem with my 11R with any other guitar or input. I purchased a Gretsch Baritone guitar which produces a noticeable buzzing sound when I plug it into my 11R. It does not do it when I plug the same guitar into one of my standalone amps - only the 11R. The buzzing stops when I touch the guitars pickup selector or volume or tone pots. Therefore I thought it was a faulty ground. But it does not occur when plugged into any other amp? Any thoughts? Thx.
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII. |
Re: Buzzing From One Guitar Only
And other guitar(s) are fine in the 11R?
Does the Grech have a pre-amp built in? (DC offset would be my thinking)
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thx for the reply. It does not happen with any other guitar or a mic for that matter. The Gretsch does not have a built in preamp.
They are called mini humbuckers.
2 thoughts:
1) the humbuckers are not wired correctly and are in single coil mode, but I would think the amp would make similar buzzes 2) the 11R's input impedance is just a little lower than the amp and the Grech doesn't like it
Check all the wiring looks OK/is factory correct. Gretch have some wiring diagrams online, check to see if you can find one there for this guitar. Especially broken or poorly connected ground wires. I don't think (but am not sure) the factory minihumbuckers are three wire/single coil splittable, but check and see it they are/were upgraded/that is what is happening.
maybe youre using higher gain model on the 11r than the real amps u have?
Took it back to the tech at my local GC. He and manager decided not to mess with it so they ordered me a new one. I will let you know. Thx.
Weird buzzing noise when recording guitar with Mobilepre MK2 | hyyz17200 | FireWire & USB Audio Interfaces (Win) | 4 | 05-14-2013 07:12 AM |
buzzing? | James522 | Pro Tools M-Powered (Win) | 0 | 07-17-2010 07:31 AM |
Mic buzzing | oulablank | Tips & Tricks | 1 | 11-13-2008 07:31 PM |
What, the buzzing? | aidanc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-11-2006 04:16 PM |
Can I get rid of Buzzing? | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-22-2003 01:20 PM |
