Old 12-26-2016, 08:17 AM
ManuVale ManuVale is offline
Default Re: Mbox Mini Knob Gain problem
Hi, I know this is an old thread but I just came up having the same problem. Since this discussion seems to be still open, I am wondering if someone came up with a solution. Thanks for any hint. Cheers
MacBook Pro, Late 2011
2,4 GHz Intel Core i5
RAM: 8 GB 1333 MHz DDR3
OS X 10.9.5 (13F1077)
AI: Avid MBox
Old 12-26-2016, 08:33 AM
Solution to what problem? The most likely issue in this thread is user experience level with low-output mics, mic use technique, and dealing with cheap low-gain/not great mic preamps etc. There is unlikely anything just broken that needs to be fixed with hardware or software.
What exact problem are you having? output from the mic sounds too low? Not seeing the input track meter level you expect? You monitoring through Pro Tools or hardware monitoring? into what monitors or headphones?
What you are recording with what exact mic, where/how the mic is placed etc. What input levels you are seeing on Pro Tools meters (you should *not* be aiming to clip the red, nothing wrong with say tracking at -20dBFS)?
If the mic signal is genuinely too low for the preamp gain and you cannot improve levels by placement/technique etc. then you can look at an external preamp or booster like a Cloud Lifter. If the mic is a condenser then check the phantom power voltage... but I'll bet it's more likely a low-sensitivity dynamic mic.
Old 12-26-2016, 09:38 AM
Hi Darryl, I do not have problems in recording. The input level is ok. I was just wondering why the signal jumps so drastically after the gain knob has been opened more than 3/4. Is this a normal behaviour of the interface or is this something which needs to be repaired?
AI: Avid MBox
Old 12-26-2016, 10:05 AM
Nope that is working as (poorly) designed. But you do not want to be running these cheap preamps near their max gain anyhow because they will sound horrible.
Mbox Volume Knob 0dB Unity Gain zenstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-01-2012 02:06 AM
Mbox gain knob problem unripevocal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-05-2011 11:38 PM
MBOX2 MINI Gain knob high rumble! barismanco123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-20-2011 05:26 PM
Mbox 2 mini and mix knob Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-03-2009 04:20 PM
using outboard pre w/mbox - gain knob setting? sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-11-2005 09:35 AM
