Analog Factory crashes PT 8cs3 on session load
Analog Factory that came with my Pro Tools HD2 bundle crashes upon load. I had 1 simple Instrument Track with 1 region as I was building an 8 bar loop for a hip hop client. Saved and opened next morning... now it crashes.
I made a new session, and imported session data track by track until I isolated which track was the culprit. Importing this track to the new session crashed that session too! So I pulled the Analog Factory plugin out of the plug in folder, and put it into unused plug ins. Now the session opens just fine. So clearly a bad plug in... What up wit dat? |
Re: Analog Factory crashes PT 8cs3 on session load
I updated to the recommended version of Analog Factory (2.1.1) and now I have even worse problems with this plug-in. If I try to insert it onto an instrument track, I get the message, "The plug-in could not be made active because a DAE error was encountered (error #-7125)"
Could somebody else just check this and make sure that it isn't just my system? I trashed preferences and everything and I still get this error. I am going to check and see if there is a newer update to this plug-in. The update couldn't possibly be worse than this.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Okay. So I found this:
http://www.arturia.com/evolution/kb/...ry&EntryID=107 I followed the instructions and now I am getting exactly what the Original Poster said. I can not find a newer update for Analog Factory SE. This is bad. I am in the middle of a project where we have tons of these plug-ins throughout. The full version has a version labeled 2.2.1 which specifically states that it fixes a bug with Pro Tools 8 and Leopard. Is there anybody using the full version that can verify that it is working fine?
No one is using this plug-in????
Okay. Time to install the old version, print tracks and say bye bye to that plug-in. Digidesign NEEDS to take that plug-in off the compatibility list since the only version that has ever worked for me was the very original version that came with the CD---but definitely is unstable after 8.0.1.
Congratulations to Kamikaz22 for finding out how to fix this issue on this thread here: (towards the bottom of the second page)
http://duc.digidesign.com/showthread...47#post1457647
protools 11.01 close session crashes on load next session | eddie lamb | Pro Tools 11 | 2 | 09-07-2013 01:51 AM |
Analog Factory crashes / any updates ? | paulseling | Virtual Instruments | 7 | 02-20-2010 11:40 AM |
Win 7, PT 8.0.3 Crashes on session load | tanona | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-05-2010 12:57 PM |
LE 7.0 crashes when trying to launch program (Factory plug-ins won't load) | Severa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-09-2009 01:47 AM |
PT 7.0 crashes when I load a particular session | phentalmyst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-08-2006 11:58 PM |
