Old 04-16-2003, 12:27 AM
pcl pcl is offline
Default writing plugin automation with remote MIDI controller
hi-
i used to write plug in automation with my peavey PC 1600 midi control surface.
i no longer have it and am wondering if it is possible to write plug in automation using say, the mod wheel or data slider on my kurzweil k2000.
i'll be damned if i can figure out how to do it.
(forgive me for stating the obvious here)
even if you knew the CC numbers for the plugin parameters....plugins are on audio/aux channels (not midi).
is remotely writing plugin automation only possible with dedicated MIDI controllers that you can enable in the Periphrials (controllers tab) dialogue?
as much as i practice drawing automation, i am never as satisfied with the result as when i enter the data with a physical controller (other than a mouse
i have done an exhaustive search on the DUC and cannot find anything on the subject.
thanks to all.
pL
Digi 001, PTLE 5.1.3cs (32 track), b/w g3450, os 9.2.2
it is not a world of men, machine...it is a world of clock watchers.
Ricky Roma
Glen Gary Glen Ross
Writing plugin automation causes clicks vitolanzafame Pro Tools 10 8 07-15-2016 07:43 AM
Writing automation without deleting MIDI notes lostsherb88 Virtual Instruments 1 11-28-2011 05:32 PM
Writing send automation with controller tha]-[acksaw Tips & Tricks 7 11-21-2011 09:22 AM
RTAS Instrument Automation Writing From Midi Controller tekk Pro Tools 9 4 08-04-2011 10:46 AM
Recording Plugin Automation with a Midi Controller Issue realitypoint Pro Tools M-Powered (Win) 9 05-16-2007 06:20 PM
