Old 11-13-2022, 10:13 PM
aftermid aftermid is offline
Default System Usage
A curious thing is happening with one of my sessions, that wasn't happening before. The system usage memory CPU is peaking at 100%. I've deactivated all the plug ins in the session and played with cache and ram settings. When I close the session, the CPU is still peaking at 100% with no session open.
If I quit Pro Tools and restart, then the CPU goes back to normal. This anomaly only started happening with this session, even though I haven't added anything to the session. What's stranger is that once the session is closed, the CPU is still peaking at 100%. When this happens Pro Tools is the only program running.
Also, tried deactivating all tracks and putting all plug ins in unused folder. Still same problem. Any ideas?
Computer Specs: Mac Mid 2012 16GB Ram. 3.4Ghz Quad core processor, OSX High Sierra, Pro Tools Ultimate 2020.12.1
Old 11-13-2022, 11:06 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: System Usage
If you create another session does it happen again?
If not, there is nothing in the session? If there is content, what about Import Session Data into a new session without problem?
If the problem does not occur, I might suppose the session is corrupt and that would be a decent resolution if nothing important is lost and future sessions seem OK.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 11-14-2022, 01:27 AM
I think there was one old version of PT where dynamic plugin processing was broken and PT would not "release" CPU time for non-mono tracks. Not sure which one but I'd try a current version of PT and see if that helps.
Old 11-14-2022, 01:38 AM
Ben Jenssen's Avatar
Any activity in the Task Manager window?
What does Activity Monitor say about PT CPU usage?
Old 11-14-2022, 01:59 AM
Emi's Avatar
Emi Emi is offline
Usually when PT starts to do wierd things, first thing I do is delete preferences, empty bin and restart computer.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 11-14-2022, 01:58 PM
I would think, if I close the session, the CPU would go down, but it doesn't. The CPU only goes down, if I quit and restart Pro Tools. Only then, if I open another session, do I get normal CPU levels. If I open the session in question, I get the high CPU levels. If the session is corrupt, shouldn't closing the session bring back the CPU levels back to normal without having to quit Pro Tools?
Old 11-15-2022, 08:04 AM
Trashing prefs is step #1 for any odd behavior, so start there
Old 11-15-2022, 11:23 AM
nednednerb's Avatar
That's just it, if the session was corrupt, how many things could then go wrong? Depends on the nature (potentially random) of the corruption.
___
>> me: nednednerB //
Old 11-15-2022, 07:46 PM
Ok,
Trashed preferences this made no difference. In Pro Tools Ultimate 2020, the preferences are stored in a folder called Pro Tools inside the Avid folder in the library, unlike older versions that had individual preference files like, com.digidesign.protools.plist. Now, this file is still in there, probably left over from when I had Pro Tools 10. Not sure, if that would be relevant.
When I trashed Pro Tools Ultimate preferences, I restarted the computer and opened Pro Tools. Without even opening a session, the system usage was showing already 50%. That was worse than before, when opening Pro Tools with no sessions opened showed a usage of about 5%. When I tried opening the session that's been giving me problems, Pro Tools hangs and the task manager says Pro Tools is not responding.
Old 11-16-2022, 12:12 AM
Emi's Avatar
Emi Emi is offline
What about a fresh install?
Total PT System Usage: CPU Usage at 100% with Nothing Running TMNTfan Pro Tools 2019 11 11-28-2019 04:34 AM
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
CPU usage error?! System usage 2%... pascalmowla Pro Tools 12 3 03-10-2016 12:00 PM
Good System Usage/RTAS settings for Quad Core system Mental Clarity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-19-2008 03:09 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
