Old 02-20-2020, 11:42 AM
WhereIsMyMind WhereIsMyMind is offline
Default Tempo changes and Elastic Audio within a song ?
I have a session with tempo changes for the choruses which are a little faster than the verses.
In that session I use Superior Drummer so tempo changes aren't a issue. The band I work with realize after the fact that the song could be a little faster but everything was recorded in audio.
If I put the audio tracks in tick mode and I turn on Elastic Audio, everything works fine until the first tempo change. For example the bass track doesn't go faster on choruses. The guitar track do. Why ? The only difference I see that could explain that was that the bass track is 1 big clip when guitar track are made of several audio clips. I try to cut the bass track but it still doesn't follow the tempo changes.
Any ideas ?
MacBook Pro 15' Late 2018 | 16 GB RAM | macOS 10.14.6
Pro Tools Native v11.3.2
Old 04-09-2020, 01:32 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Tempo changes and Elastic Audio within a song ?
Originally Posted by WhereIsMyMind View Post
Any ideas ?
In my opinion, elastic audio leaves much to be desired. It should be reworked by Avid.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Can't change tempo in elastic audio Thenewexhibit Pro Tools 12 1 03-17-2016 03:06 PM
Slowing Down The Tempo of A Song Using Elastic Audio greenskyroly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-15-2010 03:55 PM
How do you Change the tempo to part of a song using Elastic Audio? jtknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-17-2009 09:49 AM
Problem with Elastic Audio when changing the tempo of song fenderjose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-25-2008 07:02 PM
locking a free time song to a tempo using elastic audio ganglion Pro Tools TDM Systems (Mac) 6 02-24-2008 05:01 PM
