Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 03-03-2015, 08:42 AM
Dave Brannan Dave Brannan is offline
Default Pro Tools Express - No PC Playback
I have Pro Tools Express (10.3.3) and track using an Akai EIE Pro. All is working ok except I have no playback via my PC. Even using a blank session with all IO defaults and just a click track, the playback is only through the Akai interface.
If I check Tools - Playback, only the interface is available, there is no dropdown list for me to select a different playback device.
Any ideas greatly appreciated.
Old 03-03-2015, 09:19 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Default Re: Pro Tools Express - No PC Playback
I think what you are describing is the "normal" situation for Pro tools. In fact, one of the Avid recommended optimizations is to disable the computer's on-board sound card.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 03-03-2015, 10:09 AM
Thanks for the reply. I presumed when I watched videos of others using Pro Tools that when they played back audio, it was coming through their PC's.
The other thing that threw me is I can't seem to use Pro Tools without the interface being plugged in. I was trying to process my tracked sessions "offline", surely that's a normal use case?
Old 03-03-2015, 10:19 AM
For older versions of Pro Tools (like mine), you had to have an Avid (Digidesign) interface attached to the computer and turned on to use PT. I think that changed with PT 9. If you want to use the audio card in your computer, you will need to install the ASIO4all driver. I believe it is a free download-try Googling it, and download the correct version for your version of Windows. Then you wouldn't need your interface plugged in. But I don't know of any advantage to doing that. I am not an expert in audio cards or non-Avid hardware, so maybe someone else with more current knowledge can chime in and correct me if necessary.
Old 03-03-2015, 10:25 AM
sw rec sw rec is offline
I can't imagine why anybody would WANT to use the onboard audio (read: cheap) unless it's a portable rig and you just don't want to haul around a lot of extra stuff. But I'm saying this with NO info about your particular setup. Is it a laptop?
Old 03-03-2015, 10:42 AM
Correct I use my laptop in a home studio type setup. My plan was to connect my laptop to the interface, track the instruments I need (currently drums only) and then do all the post-processing "offline". If this is not really possible I'll do it all connected to the interface.
Old 03-03-2015, 10:58 AM
The Weed's Avatar
The Weed The Weed is offline
You need some form of interface to get the sound "out" either a dedicated interface or your onboard soundcard. Somewhere you have to have D to A converters in the chain. If you are using PT 11, your onboard soundcard should not be used for Pro Tools, that should be for Windows audio and a separate interface should be used for PT.
If you want to use your onboard soundcard for Pro Tools you'll need its ASIO driver or, as suggested, ASIO4ALL. Disable you're other interface and use the onboard for PT. Once you go back to your interface, make your onboard soundcard the default again and enable your interface for PT only.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
No Stereo Mix Via Playback in PT Express RobiusRecording macOS 1 11-11-2014 02:36 AM
Pro Tools Express Hangs Permanently after Stopping Playback robertallen Pro Tools Express on Windows 0 06-20-2014 04:49 PM
Cannot hear playback in Pro Tools Express? neioos Pro Tools Express on Mac OS X 3 06-10-2014 09:36 AM
PT 11.1.2 BlackMagic Express Black Drop Outs / Flickering on Playback Stop Nathan W. Post - Surround - Video 3 05-16-2014 12:37 AM
No playback sound in Pro Tools Express ramadei Pro Tools Express on Mac OS X 3 10-31-2013 01:51 AM
