purging session of region "slivers"-automatically
Hello All,
Does anyone know of a fast way to purge an entire session of small region "slivers"? I do know how to properly edit in such a way as to avoid this most of the time; but often because of time and or $$$, I'm micro & macro editing at the same time "down & dirty", using a combination of tab-to-transient, Beat Detective and copy/paste, focusing mainly on intonation/pitch, groove/performance. It would be ideal if I could do the following: -edit an entire mulit-track PT session w/o worrying about how neat any of my edits are. -when finished, highlight all regions, tell Pro tools to remove any region smaller than 10 ms from the active playlists -batch fade -then listen to make sure all the edits are smooth. I hope I explained this well. Does any have a method for this? Thanks in advance. |
Re: purging session of region "slivers"-automatically
command shift U
command shift B Enter
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
wouldn't that just clear all unused audio?
I just would like to tell pro tools to clear all regions in a playlist that are under a specified length, say, 10 ms. You know, the ones that mess w/ making proper cross-fades. The ones that you have to zoom in to see, and then clear, before you can "button up" a track? |
sorry, I suppose I didn't fully read your post.
good luck
Threshold 0dB Min. Strip Duration 15 msec Region Start Pad 0 msec Region End Pad 0 msec Extract Timothy |
I think strip silence would assume that the "slivers" have no audio in them, which may or may not be the case.
Worked here - when I tested it quickly. But maybe I made a mistake. Timothy |
ahh, yes.
That does seems to work. I'm gonna test this more. If this work reliably, you just gavr me days , maybe years of my "life" back. Thank you so much! |
"Compiling" multiple sessions into one "Master" session. Any pointers? | Nollykin | Tips & Tricks | 17 | 12-09-2013 10:36 AM |
Inputs automatically reassigning after selecting "no input" | BrianJArmstrong | Pro Tools 10 | 4 | 05-30-2012 09:12 AM |
"Pro Tools not responding" error and a very "laggy" session! Help! | drumbumd | Pro Tools M-Powered (Win) | 0 | 02-10-2012 05:37 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Region List "Bins" / "Folders" | Styles Bitchly | Pro Tools TDM Systems (Mac) | 1 | 06-18-2010 01:22 PM |
