Old 12-20-2006, 09:33 AM
tonmeistermat tonmeistermat is offline
Default mojo suddenly stops working with TL Space
I've got a mojo, and it's been great up until now.
All of a sudden it won't play out a QT that was working fine this morning. I was mixing this morning, no problems, then I switched off the TV (so I could get rid of that 15k whistle - it's an old telly) and continued mixing for a while. I then switched the TV back on, and the screen was black. The mojo looks to be working fine, there's no error messages, but nothing seems to be appearing on the screen. Other projects work fine, but not this one.
I've been trying to get it working all afternoon, but to no avail. I fear I may have inadvertantly done something silly, but I'm not sure what.... any thoughts anyone?
Mat
ICON D-Command, PT 7.2cs2 HD3, G5 PowerPC Dual 2GHz. A bunch of plugins!
Old 12-20-2006, 09:44 AM
DigiTechSupt's Avatar
Default Re: mojo suddenly stops working - help!
What version of Pro Tools 7 and Quicktime are you running? Have you tried rebooting the system and powercycling the mojo?
Avid Audio Tech Support
Support FAQ
Old 12-20-2006, 11:11 PM
blue demon blue demon is offline
A mojo not working properly? I've never heard of such a thing!
I had the same thing happen to my and I had to reboot the computer, and also reboot the mojo itself. I've noticed that I can't work as fast on a Mojo system that I do on a regular system because it tends to be a bit finicky, and can get freaked out if you move too fast.
-BD
Film in America.
Old 12-21-2006, 05:27 AM
I'm running HD2 7.2CS1, with the latest version on QT, on a dual 2.0 processor mac.
The first thing I did was powercycle the whole system - to no avail.... however, after much fiddling and experimenting, I've worked out what's causing the mojo to go black. when I had the screen switched off I inserted three TLspace verbs on my effects returns. Once the mojo has gone black, the only way to get it back again is to remove the inserts, all three of them, and re-boot the system. Then it works fine.
There is still plenty of spare processing on the system usage display, so I don't understand why 3 TLSpaces would cause the mojo to do this. Any thoughts anyone?
And yes, the mojo does seem to be more 'delicate' than my old canopus when running QTs. It's perfect running AVID video though. Ho hum, you can't have it both ways I suppose!
Is there a way of converting QT into AVID video files? I'm assuming you can do it with MediaStation, but I'm still waiting for it to arrive (only been waiting 4 weeks since the date I was PROMISED it would be delivered, thanks digi)
Mat
Old 12-21-2006, 05:40 AM
pat yacono pat yacono is offline
One TL space will do this. Happens everytime for me, is repeatable. I reported it to DIGI awhile ago.
Old 12-21-2006, 11:53 AM
What version of TL Space are you using and are you instanciating a RTAS or TDM version?
Support FAQ
Old 12-21-2006, 04:51 PM
I'm not using MOJO, but I did have a mixer tell me today that when he uses TL Space TDM, something goes awry with the Canopus ADVC-110. This is with v7.2cs1. It sounds like TL Space TDM is a common denominator here.
Old 12-22-2006, 03:44 AM
I'm running TLSpace TDM, latest version (I only installed it about a month ago) I think.
I'm not in front of my machine right now, but I'll confirm it when I'm back in the studio after the vacation. It's a bugger that this happened 2 days before the Chrsistmas holidays, as I'm not going to be back in the studio until 2nd of January.
Pat, what do you do to get around this problem?
Mat
Old 01-02-2007, 07:12 AM
Back in the studio now - happy new year everyone!
Spec is: ProTools HD2, version 7.2cs2 running on mac G5 dual 2.0 with 2.5 gig ram
TL Space, version 7.2.1
I've done some more experiments, and sure enough once TL Space has been inserted on track (works fine as stand-alone though) the mojo goes black and stays that way until it is rebooted, even if the session is closed and a totally new session is opened that does not contain TL Space.
This is a serious problem for me - is there any work around at all for this? Help!
Mat
Old 01-02-2007, 07:56 AM
We are aware of the problem and are looking into the cause and a fix for it.
Support FAQ
HTML code is On
Space bar stops then goes back to beginning TestPilot Getting Started 4 01-07-2014 01:01 PM
my metronome suddenly stops - protools SE andi561 Pro Tools SE and Essential (Win) 1 12-24-2012 11:03 AM
Digi 002 Standalone MST Output Suddenly Stops mattrw89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-07-2006 12:59 PM
Midi Stops outputting suddenly? PMoshay Pro Tools TDM Systems (Mac) 3 04-23-2004 09:59 PM
session stops and suddenly starts rattling,? help onecrackedmind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-03-2004 08:29 PM
