#91
Re: Logic Pro 8
I don't miss the maze of cables, interfaces, dongles ETC It's a interesting idea Open notebook, Press power button, Launch program Scary simple
#92
Re: Logic Pro 8
We have different opinions about what the important differences between Logic and PT are, and I won't go into that - but here's some info regarding what you just wrote: Logic 8 is apparently optimized for handling a lot more tracks than Logic 7 was - I've recently been in touch with a Logic user who played 70+ 96kHz tracks from one drive - in 24 bit. The test was done with interleaved stereo tracks - so 140 mono tracks shouldn't be a problem. I just did a test on my first generation MBP and could record 'only' 26 tracks, but that was @ 192kHz. Fifty 96kHZ tracks- in 24 bit - on a 2.16 CoreDuo MacBook Pro shouldn't be a problem. No platform war intended, both DAWs have great stuff the other application doesn't have, but these facts may explain why individual track allocation isn't a 'dying wish' in Logic 8. |
#93
Re: Logic Pro 8
Did you have to upgrade the OSX to 10.4.10 for Logic 8 ? 10.4.10 is not qualified with PT. Is it ? Cheers Lizardpoint |
#94
Re: Logic Pro 8
some one must love it, I found this add last night
http://losangeles.craigslist.org/lac/tfr/426931138.html
#95
Re: Logic Pro 8
Logic 8 requires OS X 10.4.9. Pro Tools is not qualified for 10.4.10.
#96
Re: Logic Pro 8
The Greatest Risk in Life is Doing Nothing |
#97
Re: Logic Pro 8
With Logic running not in DTDM mode, can audio unit tracks be routed through 24 or more ADAT lightpipe channels (on an interface like a MOTU 2408) to return to 24 TDM aux ins via 192 lightpipe ins? Or if the TDM mixer is instantiated are the core audio outputs limited to 8 like the limitations of the ESB bridge? Oh, and does a legacy interface like an ADAT bridge work in Logic with a HD system? DISTRIBUTED AUDIO PROCESSING Has anyone tried the distributed audio processing feature in Logic? Compared to not using any "node" processing, Does using a node plugin change the latency of that channel or the whole audio output? How stable is distributed audio processing? If anyone can shed light on any of the above questions it would be most appreciated. If Logic's Distributed Audio Processing works reasonably well then in theory one could add additional computers like adding Accel cards- close in price, and use AU plugins at half the price of TDM (and hopefully less problems than seem to accompany RTAS versions). Authorization could be a problem as the node machine would have to be authorized, but couldn't one have a Waves machine, and a Sonnox machine, and a URS machine and a bomb factory, oops, scratch that last one. Basically have the host machine do VI's and au and logic plugins, and have a node machine doing logic plugins (no auth needed) and an offload of 3rd party AU plugs? Oh, devil - in - the details- one- more question, to use Logic 8 with AU plugins on node machines do those au plugins have to be a special version, or are most third party AU plugins already capable/compatible for this purpose? |
#98
Re: Logic Pro 8
#99
Re: Logic Pro 8
#100
Re: Logic Pro 8
Logic 8 to logic 7 session won't open! saving procedure need | crizdee | Pro Tools TDM Systems (Mac) | 9 | 04-26-2008 08:09 PM |
Logic Pro users: Midi & audio between Logic & PT | dtmprod | Pro Tools TDM Systems (Mac) | 4 | 09-24-2006 04:16 PM |
tdm logic plug in automation in logic 7? | quincygriffin | Pro Tools TDM Systems (Mac) | 5 | 05-23-2005 09:08 AM |
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? | uno1234 | Pro Tools TDM Systems (Mac) | 13 | 04-28-2002 04:23 PM |
Hello Logic users.......Please explain about Logic Midi | elik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-04-2001 12:35 AM |
