Hardware problems with OS 10.4??
Hello All,
Vaguely I remember reading a post about certain imcompatabilites between older revisions of ProTools HD hardware, PT version 7.0+ and Mac OS 10.4+. I tried to search for it (No, really, I did) and couldn't find it. The reason I bring this up is that I recently tried upgrading one of our MDD G4 (1.25 gHz) from PT 6.4/ OS 10.3.5 to PT 6.9 and OS 10.4.2. When launched, ProTools said that it was unable to find the hardware (HD2). I removed the cards, re-seated them with the same results. Installed 10.3.8 and the whole thing was happy. Is there any else who has had a similar problem? Most of our HD cards and I/O are older (if that helps) Randall
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
Re: Hardware problems with OS 10.4??
i've had input 4 on my 192 out for some time
making white noize constantly it seems i'm thinking of reseating the card before i pay digi 300 buck for a trade in ahhhh to find or make the time!
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I am having a similar problem to you own except the host machine is a '1st gen.' G5 1.8 dual, OSX 4.3, PT 7.0. The Mac system profiler does not register any PCI information even though the Core and Process cards are fitted. PT fails to launch, halting at the 'please connect hardware' warning. The cards and 192 interfaces have worked fine for the past three years when installed in a G4 daul 1.42, OSX.3.9, PT6.4. Any help would be much appreciated Cheers |
If you've moved or changed or removed any of the stock cards in a 192, it may not be recognized properly with Pro Tools 7.0. Updating to 7.1 should clear up the problem if this situation applies to you.
hey,
i've had the same problem. i tried everything. Then i put the digilink cable and the serial cable to the processer card. and that worked. i dont know why it works . But i am trying to figure it out. mike |
as you suggested, I installed the PTHD 7.1cs6 software but to no avail. The problem persists.
Digitest does nothing! 'no information' message in the Mac system profiler persists! Audicore manager indicates Digidesign HW: unsupported device/Status Not connected no HW found! For some reason the core and process cards are not being recognised, yet the 192 interfaces perform the normal orange ring to green ring transistion when the Mac is powered up. Thanks for your input |
Hardware set-up problems | matty700 | macOS | 1 | 02-27-2012 07:17 AM |
Hardware Problems!! | babatash19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-21-2010 07:14 AM |
Help! Problems with ProTools 6.1/hardware | Awespishus1 | Pro Tools TDM Systems (Mac) | 1 | 07-19-2007 03:50 PM |
Hardware problems | dB Music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-18-2003 04:55 PM |
hardware problems wih dual g4? | tonspur | Digidesign Hardware & Software | 0 | 10-21-2002 03:07 AM |
