Firewire H Drive for M Box.
Hi there all.Posting from Downunder.Anyone know if the Digi 80 or the Avid rs Firewire are worth the purchase to run with M Box for home studio project with acoustic guitar.Are these firewire drives outdated?IF not, what are the advantages of these drives( digi and avid are not cheap) if so,what is the better alternative HD in firewire? (heat dissipation and no noise! )
Gazza |
Re: Firewire H Drive for M Box.
IMHO
Go for a simple (pc style) Firewire HD! They are cheaper then Digi Drives and they work great. Just be shure to but a firewire enclouser with the OXFORD 911 CHIPSET, as Digi said here http://www.digidesign.com/compato/osx/stg/firewire.cfm Although not fully tested and supported with Pro Tools systems by Digidesign, you may be able to use firewire drives from other manufacturers with similar results, given the same guidelines noted above. To date only Firewire drives with the following specifications have performed well with Pro Tools systems: Oxford 911 Firewire bridge chipset 7200 RPM drive Check with the drive manufacturer to verify that their drive has the "Oxford 911" or comparable chipset & drive speed of 7200 rpm. |
Any benefit of 2nd internal drive for audio instead of firewire drive? | JChance | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-15-2009 06:25 AM |
Firewire question... 002R + firewire drive? | luts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-26-2008 06:51 AM |
How can you use an external firewire drive and Digi002 with only 1 firewire port? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-16-2003 01:11 AM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
Updated to 5.1...now firewire drive "not valid audio drive"" | blink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-11-2001 05:23 AM |
