Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
  #21
Old 04-14-2016, 08:49 AM
easyrider easyrider is offline
Default Re: Drum Overheads
Right I have decided :)
Oktava Mk 012-01 MSP2 Matched Pair
Can get these for £229 shipped to the UK
Seems to get rave reviews for the cost to performance ratio.
  #22
Old 04-14-2016, 02:08 PM
cwsand's Avatar
cwsand cwsand is offline
Originally Posted by mesaone View Post
yeah those PZM overheads are definitely not following the 3:1 "rule" of stereo pair placement.
Technically the 3:1 rule applies to 2 mics recording 2 different sources, not a stereo configuration, though it may have merit in this situation too. I agree that you'd probably get a more spacious image if you spread the pzm's much further apart.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
  #23
Old 04-15-2016, 09:58 AM
mesaone mesaone is offline
It's for 2 mics recording the same source. In this case, the source is the drum kit, although you could easily argue that the kit counts as several individual sources.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #24
Old 04-15-2016, 01:37 PM
https://soundcloud.com/easy-rider-91223276/easy-test-2
Here is a clip of just one PZM nothing else..a bit of EQ and some reverb.
  #25
Old 04-15-2016, 09:46 PM
cwsand's Avatar
That's the common misconception, but the 3:1 rule applies to 2 mics on 2 sources, not a stereo configuration. The pzm's in the picture are basically a spaced pair, which are not phase-coherent.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
  #26
Old 04-18-2016, 05:23 AM
Do you think its worth getting this set?
Oktava MK-012-20 MSP8
http://www.oktava-shop.com/category-...2-20-MSP8.html
Comes in at £572 and offers 4 mics in one... Should offer me some more options when recording more than just drums.
MK-012 small diaphragm - cardioid, hyper cardioid, Omni-directional; MK-102 large diaphragm - cardioid
Thanks
P.S I've made some changes to my drum setup. I've addressed some issues you all brought up.I'll post some picture later...Feedback welcome
  #27
Old 04-18-2016, 06:55 AM
Marsdy Marsdy is offline
Thanks
That's a no brainer IMO. I'd add a stereo T bar to your budget. They're only a few pounds. A coincident pair or ORTF pair is the ONLY way to properly record drum overheads!!!! (Ducks for cover.)
Dave Marsden
UK
  #28
Old 04-18-2016, 07:29 AM
T bar and two of these
Tech:Quantum and ASP880 / Yamaha MT120S / Ryzen 5950X /Win 11 Pro 64-bit /Pro Tools 2023.12/ Shure DMK57-52 /Neumann TLM 102/ Oktava MK-012
Mic Pre's Focusrite ISA One/ DAV Electronics BG1/ Joe Meek VC3
Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/
Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R
  #29
Old 04-18-2016, 07:35 AM
Agreed except Studiospares do a much cheaper one. Not as nice but if budget is being stretched.
Dave Marsden
UK
  #30
Old 04-18-2016, 09:26 AM
Just a hint for the Oktavashop - log in to see cheaper prices. Those shockmounts are 24,90 EUR when not logged in and 20,92 EUR when you log in. The MSP8 set is 789,01 EUR when not logged in but 663,03 once you log in. That's a significant amount.
I found this out when buying some swivel adapters and fig-8 capsules last year
By the way, the MK-012 makes a fantastic vocal mic, believe it or not. Here's mine from a somewhat recent session. Cardioid capsule with an added swivel adapter, shockmount, and pop filter. http://i.imgur.com/j2riAuc.jpg
Also, a tip for the stereo bars with these mics... To get XY pattern, one mic needs to be elevated above the other.. Raising one of the mics is easy if you just take two adapters (one 3/8-5/8 insert adapter, one 5/8 to 3/8 adapter) and put them together on one side of the stereo bar to form a riser.
If that's the case, I've been walking around with that misconception for awhile. Oops. But it's okay, I break the rule all the time when it sounds good.
OT M-S Drum Overheads flommer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-13-2006 07:33 AM
Drum Overheads - How Do *You* Like to Mix? rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2005 02:42 PM
Drum Overheads skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-25-2004 05:51 PM
drum overheads mbuono Tips & Tricks 10 11-20-2003 11:10 AM
Drum overheads sound without overheads d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-12-2003 06:57 AM
