Old 08-22-2006, 05:34 PM
humpback humpback is offline
Default Bypass all inserts?
I feel really dumb asking this - cuz I figure I should know how to do this by now - but is there a way to bypass multiple plug-ins at once on a track? For instance, if I have an EQ, compressor, and smack on a track, and I want to listen to the raw track sans plugs, I now have to click each one and bypass it. Its a small thing, but if I want to A/B, it can be less than efficient. Any thoughts?
DIGI: If there is no way to do this, I hereby request this be considered for the next version.
cheers,
Nathan
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x Summit Audio 2BA-221>TLA 50>EQF-100
2 x dbx 165a
4
x Shadow Hills GAMA
http://humpbackmedia.net[/SIZE]
Old 08-23-2006, 04:14 AM
accession accession is offline
Default Re: Bypass all inserts?
Forgotten exactly off the top of my head...
...the secret lies in clicking the plug-in on the insert while holding down the Apple key, or Control key, or Alt key, or Shift key, and combinations of them.
There are two modes that may be switched:
Bypass - like hitting bypass with the plug-in window open
Disable - same as bypass, plus it fully takes the load off the processing CPU. Great to save some power if you need it, without losing your plug in settings or routing.
Sorry to not be exact on the keys, but it is possible to do what you want.
Old 08-23-2006, 04:16 AM
Sorry, just to add, one of the keys will cause *all* inserts across the row of the insert you clicking on to be bypassed/disabled.
Old 08-23-2006, 05:22 AM
Ben Jenssen's Avatar
Cmnd-click on PI: Bypass.
Ctrl-cmnd-click: Disable.
If you add option key to any of these combinations, all tracks´ PIs on that insert will be affected.
If you add shift to that again, only selected tracks will be affected.
As for bypassing all PIs on a track simultaneously, there is no real easy way. Maybe the easiest way is to duplicate the track, remove PIs and solo/mute/unmute between the two.
IHTH.
Old 08-23-2006, 05:36 AM
That's the ones! Cheers.
Old 08-23-2006, 11:56 AM
Excellent, Ben/Accession!! Thank you both for the quick and helpful replies!
Cheers,
N
Studio:
Mac Mini 2.6 GHz i7
16GB RAM
PT 2019 and 10.14
UA Apollo Quad
Outboard:
2 x dbx 165a
4
x Shadow Hills GAMA
Old 11-13-2017, 07:21 AM
amagras amagras is offline
Found this looking for something else.
You can Bypass All Inserts on all selected tracks with Shift+A.
Now what I'm looking for is how to Bypass from the any insert down, for example, how to Bypass simultaneously the 3rd, 4th. etc leaving the plugins on the first and 2nd inserts active.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
Group Inserts Bypass Bug audiokopf Pro Tools 9 0 07-21-2011 12:09 PM
Bypass button using hardware inserts johansen Pro Tools TDM Systems (Mac) 3 03-09-2009 06:48 AM
bypass all channel inserts at once tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-31-2008 09:56 AM
Shame we can't bypass inserts crizdee Pro Tools TDM Systems (Mac) 5 05-26-2005 10:34 AM
