When I quit PT 2020 - it automatically restart itself
Hi!
I have a problem w/ Pro Tools 2020. When I quit a session I save, quit the session and then Pro Tools. Pro Tools quits normally. BUT automatically restart itself! What may be the problem? Thanks.
Win11 Pro Intel i7-12700K @3,6GHz, RAM 32GB UAD Apollo and pre-amps, Pro Tools 2023 lots of plugins |
Re: When I quit PT 2020 - it automatically restart itself
Lots of reports on DUC of past problems like this. You should probably be starting there. e.g. http://duc.avid.com/showthread.php?t=406849
And unless its something as specific as Command 8 drivers or similar I suspect (always suspect) plugins. You can look for crash files and check what is at the end of each Pro Tools log file (e.g. Pro Tools may be failing to really shut down OK at the very end). |
The causes can vary but the times I've experienced this on my Windows system it's because of some Nomad Factory plugins.
Workaround for that: Deactivate the track or remove the plugin before shut down. Last edited by take77; 11-24-2020 at 08:15 PM. |
How to uninstall Pro Tools 2020.11 and revert to 2020.9.1 | ArKay99 | macOS | 10 | 02-27-2021 02:41 PM |
Avid Control App Rollback (2020.5 to 2020.3) | budster | Avid S1, S3, Dock and Control App | 2 | 06-09-2020 11:01 AM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
002R causes computer to restart automatically | amzijackson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-24-2005 01:09 PM |
