Old 10-15-2014, 11:02 PM
fmilian's Avatar
fmilian fmilian is offline
Default Unchange the I/O setup ?
I got this problem that drives me insane !
Whenver I load a project received from clients, with different I/O setup, they messed up my I/O.
And REMAINS.
Meaning, that if I load an old project (of mine), the I/O - busses, are crazy.
It seems to keep the "client" I/O, but if I load MY PROJECTS, it doesn't.
How can I LOCK my I/O, Bus list , that could not be changed by some other projects?
Every time I load or make a new project, after loading a client project, that has different outpus/inputs/busses , my project DOESN'T LOAD MY OLD SETUP and it's messed up with the I/O that remain from the client project setup.
Florin Milian
OS X 10.9 / Mac Pro Early 2009 / 12GB Ram / Protools HD 11 with HD Omni/Native Core.
PC Intel Quad Core / Protools LE 8.0.3 / Digi Rack 003+ / Win7-64
Old 10-15-2014, 11:34 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Unchange the I/O setup ?
And REMAINS.
In the I/O page.... "New sessions overwrite current session"
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-16-2014, 12:30 AM
fmilian's Avatar
It is NOT checked.
Because I DON'T WANT the I/O to be changed.
So, I must check it so the I/O to be changed?
And this way, when I save the session, it will contain the I/O I used, and loading it, will restore the I/O used in the project?
Florin Milian
Old 10-20-2014, 09:35 AM
muesli muesli is offline
good question!!
i think there's no way to leave the own i/o setup unchanged - i tried several things - if anyone knows how to do that, please tell us!
MacPro 12-Core, 48 GB RAM, OS 10.12.6, PT Ultimate 2019.12.0 HDX, Antelope Orion32HD III
http://17-studios.com
Old 10-22-2014, 12:01 AM
dwaynedelario dwaynedelario is offline
You could import session data into your template and not take the I/O assignments from the client sessions. If you need to match session start times, just go to import and check the start time of origin session in the report window, cancel and set your session start. Then go back to session import and take the tracks, tempo map etc but not the inputs, outputs and buses. Might be psychosomatic but I find my sessions behave better this way as well.
Old 10-22-2014, 05:11 AM
And REMAINS.
Originally Posted by crizdee View Post
Chris
It is NOT checked.
How I get around this happening is to make a preset with all my inputs, outputs, etc. and save that preset. When I get a session and I want my old setup, I just import that setup via the 'import' button in the I/O setup and it's there. It's also handy for starting new sessions.
Jack
QAPLA!
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
I/O setup doesn't reflect my hardware setup devapro Pro Tools TDM Systems (Mac) 7 12-30-2006 11:16 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
