bounce to QT showing up mono?
When I bounce to a quicktime, even when I select A1-2 (stereo) as the source and the quicktime sound option to stereo, the bounce ends up being mono.
Has anyone else seen this? Any ideas? -Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
Re: bounce to QT showing up mono?
This seems to happen if you use the 'convert during bounce' setting on an audio only bounce prior to bouncing a QT movie. If you do an audio only bounce using 'convert after bounce' (it can be a very short bounce) then the QT bounce works as expected. I switched to always converting after bounce many years ago when this bug first appeared (in PT 7 as I recall). Note that the QT window will always indicate that it will 'convert after bounce'. Hope this helps. --c
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
QT Bounce not showing video | Dopamine | Post - Surround - Video | 3 | 09-27-2012 11:09 AM |
Mono bounce | CD Productions | Post - Surround - Video | 6 | 06-25-2007 10:13 AM |
Quicktime, only mono when bounce?? | Bo Savik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-25-2006 07:59 AM |
Mono to stereo plug-ins not showing L/R pan | trostals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-20-2004 09:28 AM |
Hardware Reverb not showing up in BOUNCE TO DISK | Ustad Khan Ali | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-22-2004 09:29 PM |
