Old 09-29-2011, 07:55 AM
mafiacondon
Guest
Posts: n/a
Default Can anyone read and understand this crash report ?
PT crashing alot today trying to use Trillian , Ivory and Kontakt 4 in same session , it worked when i performed the track in , recalling to mix it and trillian is made inactive , so i undid the ivory saved as 1.3 version then tried revert to saved to see if trillian would activate but crashed Again
Process: Pro Tools HD [299]
Path: /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD
Identifier: com.digidesign.ProToolsHD
Version: 8.1.1x59 (8.1.1d59)
Code Type: X86 (Native)
Parent Process: launchd [191]
Date/Time: 2011-09-29 15:51:35.242 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 223401 sec
Crashes Since Last Report: 48
Per-App Interval Since Last Report: 70576 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: D7679115-2B06-4AE8-9E3C-B511BF46B2FB
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...gn.framework.CoreFoundation 0x002e52a5 Sys_Clock::UTC2String(long long, bool, bool, EDateStringFormat) + 119
1 ...gn.framework.CoreFoundation 0x0030aa70 Sys_Utils:ebugString(std::string const&) + 66
2 ...gn.framework.CoreFoundation 0x003609d6 Sys_MachExceptionHandler::Init(bool) + 1548
3 ??? 0xe661ccbd 0 + 3865169085
4 net.spectrasonics.StyM 0x3ed4e913 CDSPProcessType::CreateProcessDeactivated(long*) + 451
5 net.spectrasonics.StyM 0x3ed35adf CEffectTypeRTAS::InstantiateProcess(long*) + 47
6 net.spectrasonics.StyM 0x3ed53ec8 CProcessGroup::InstantiateProcess(unsigned long, long*) + 136
7 net.spectrasonics.StyM 0x3ed3e707 S2ArgGroupFunc<unsigned long, long*>:perator()() + 71
8 net.spectrasonics.StyM 0x3ed5e0b1 CallAndTranslateExceptionsToReturnValues(SGenFuncR etLong*) + 17
9 net.spectrasonics.StyM 0x3ed38369 CallNoThrowCommon(SGenFuncRetLong*, unsigned char, unsigned char) + 89
10 net.spectrasonics.StyM 0x3ed3949e PI_InstantiateProcess(unsigned long, long*) + 62
11 com.digidesign.framework.DAE 0x031ba302 FicGetApplicationInterface + 98878
12 com.digidesign.framework.DAE 0x031f3a00 FicReportExternalEvent + 137505
13 com.digidesign.framework.DAE 0x0327852e FicInstanciatePlugInLovinglyAndSkillfully + 56
14 ...gidesign.framework.ProTools 0x01398a1c 0x7db000 + 12311068
15 ...gidesign.framework.ProTools 0x00c3ff8d 0x7db000 + 4607885
16 ...gidesign.framework.ProTools 0x00c403ac 0x7db000 + 4608940
Old 09-29-2011, 08:27 AM
the dude's Avatar
the dude the dude is offline
Default Re: Can anyone read and understand this crash report ?
Sure
Spectrasonics Stylus is causing a crash
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 09-29-2011, 08:29 AM
DigiTechSupt's Avatar
The crash logs don't tell us much. Can you zip up the LogFiles folder from inside your Pro Tools folder and email it to me at: vi [at] digidesign [dot] com?
Avid Audio Tech Support
Support FAQ
Old 09-29-2011, 09:26 AM
mafiacondon
Guest
Posts: n/a
the dude - Thank you
DigiTechSupt - have sent email
M
Old 10-03-2011, 11:32 AM
For anyone else looking at this thread - it appears mafiacondon has a ton of incompatible plug-ins installed. I'm having him remove or update them and test again.
Per the info in the General Troubleshooting thread - plug-in compatibility is SUPER IMPORTANT. I'm not joking. Even one incompatible plug-in installed (not even used in the session) can cause all kinds of havoc. Please, before posting about problems, make sure you've gone through the General Troubleshooting thread and have done all the troubleshooting there, especially regarding plug-in compatibility. Did I mention it's important?
Support FAQ
How to read a crash report ? Geh Pro Tools 10 5 04-17-2013 07:10 PM
Crash with PT 10.3.3 (crash report inside) powerjoe macOS 8 01-22-2013 10:33 AM
Postman, help me understand how 59.94 TC can be read at 29.97! Eric Seaberg Post - Surround - Video 9 11-07-2009 05:58 PM
Please read and give some feedback on this report izzy_white 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-13-2009 09:34 AM
Major Crash with PT 7.3 cs5 crash report included RuffJazzRecords Pro Tools M-Powered (Win) 0 02-09-2008 12:43 PM
