Old 05-24-2007, 09:59 AM
Pallus Sinfony Pallus Sinfony is offline
Default 9129 or 9093 errors when recording or playback, DAE
hey,
i installed pro tools 6.7 on my laptop to use my m-box, however i keep on getting the9129 or 9093 errors when recording or playback. It tells me to change my DAE Buffer size, when i do the errors still come up! i searched the digi site and tried the following things:
http://www.digidesign.com/index.cfm?...1&itemid=16027
http://www.digidesign.com/index.cfm?...itemid=11732??
http://www.digidesign.com/index.cfm?...itemid=18921??
http://www.digidesign.com/index.cfm?...1&itemid=21610
http://www.digidesign.com/index.cfm?...1&itemid=20375
http://www.digidesign.com/index.cfm?...1&itemid=22380 **
http://www.digidesign.com/index.cfm?...&itemid=21025?
http://www.digidesign.com/index.cfm?...1&itemid=23406
http://www.digidesign.com/index.cfm?...1&itemid=16243
the ones with the "??" i wasnt able to complete.
the following are specs on my laptop:
Processor >
Model: Genuine Intel(R) CPU T2050 @
1.60GHz
Speed: 1.60GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Mobile, Dual-Core
Internal Data Cache: 2x 32kB Synchronous, Write-Thru, 8-way set,
64 byte line size
L2 On-board Cache: 1x 2MB ECC Synchronous, ATC, 8-way set, 64
byte line size, 2 threads sharing
< Mainboard >
Platform Compliance: Intel Centrino Mobile Technology
Bus(es): ISA PCI PCIe PCMCIA USB FireWire/1394 i2c/
SMBus
MP Support: 1 Processor(s)
MP APIC: No
System BIOS: FUJITSU SIEMENS 255.255
System: FUJITSU SIEMENS AMILO Pi 1505
Mainboard: FUJITSU SIEMENS AMILO Pi 1505
Total Memory: 1015MB DDR2-SDRAM
< Chipset 1 >
Model: Fujitsu Siemens Computers 955XM/945GM/PM/GMS/
940GML Express Processor to DRAM Controller
Front Side Bus Speed: 4x 133MHz (532MHz data rate)
Total Memory: 1GB DDR2-SDRAM
Shared Memory: 8MB
Memory Bus Speed: 4x 133MHz (532MHz data rate)
< Video System >
Monitor/Panel: Plug and Play Monitor
Adapter: Mobile Intel(R) 945GM Express Chipset Family
< Physical Storage Devices >
Hard Disk: WDC WD1200BEVS-22LAT0 (112GB)
CD-ROM/DVD: _NEC DVD_RW ND-6750A (CD 24X Rd, 24X Wr) (DVD
3X Rd, 3X Wr)
< Logical Storage Devices >
N01336 (C:): 112GB (83GB, 74% Free Space) (NTFS)
Wake Up,RonBurgundy (D:): 3.8GB (UDF)
< Peripherals >
Serial/Parallel Port(s): 1 COM / 0 LPT
USB Controller/Hub: Intel(R) 82801G (ICH7 Family) USB Universal
Host Controller - 27C8
Host Controller - 27C9
Host Controller - 27CA
Host Controller - 27CB
USB Controller/Hub: Intel(R) 82801G (ICH7 Family) USB2 Enhanced
Host Controller - 27CC
USB Controller/Hub: USB Root Hub
FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller
Keyboard: Standard 101/102-Key or Microsoft Natural PS/
2 Keyboard
Mouse: PS/2 Compatible Mouse
< Communication Device(s) >
Device: Motorola SM56 Data Fax Modem
< Printers and Faxes >
Model: Fax
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Home 5.01.2600
(Service Pack 2)
Platform Compliance: Win32 x86
< Network Services >
Adapter: Realtek RTL8139/810x Family Fast Ethernet NIC
Adapter: Intel(R) PRO/Wireless 3945ABG Network
Connection
< Performance Tips >
Notice 5901: CD 1x= 150kB/s; Exercise caution when
comparing measured versus published ratings.
Notice 5902: DVD 1x= 11.08Mbps Exercise caution when
Tip 2Double-click tip or press Enter while a tip
is selected for more information about the
tip.
<<< Mainboard >>>
< System >
Manufacturer: FUJITSU SIEMENS
Model: AMILO Pi 1505
Serial Number: 504028A11F
this i s really annoying me and breaking my heart cos im doing a night course in sound eng and i have to record in song in 2 weeks fot it! argh!
has anyone come across this before??
Micheál
Old 05-24-2007, 12:24 PM
tomdiek tomdiek is offline
Default Re: 9129 or 9093 errors when recording or playback, DAE
This is actually the Mac forum, you might have better luck posting this on the Windows forum.
Pro Tools 2019.6
iMac (Retina 5K, 27-inch, Late 2015) OS 10.14.6
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
Apogee Symphony MKII Thunderbolt 2X6
Old 05-24-2007, 01:36 PM
spkguitar's Avatar
And now that the admins have moved you over here in the proper forum, you are only using one hard drive. You need to be using a separate physical disk for audio sessions. When using a laptop, this means using an external firewire drive with the approved Oxford 911 chipset.
Stinkin' DAE errors 9093, 9129 on playback in Pro Tools LE 8 lmeney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-26-2010 09:10 AM
Errors 9129 & 9093 sydstyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-23-2005 12:45 PM
Errors 9129 & 9093 sydstyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-15-2005 11:36 AM
-9093 and -9129 errors Aussie Scott 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2004 11:03 AM
Errors - 9129 and -9093 with PT 5.0.1 LE bilbob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-18-2001 04:37 PM
