Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-21-2018, 05:12 PM
jonesar22 jonesar22 is offline
Default MixPre-3 as interface... but no mic? [solved]
I'm having trouble getting my MixPre-3 to register my mic as an input on Pro Tools.
I have a USB feeding audio from my Macbook Pro into the MixPre-3 and then out again. Pro Tools can sees this and can record it.
But I have a Shure KSM32 in my second channel on the MixPre and it will not register to record on Pro Tools.
The input and output in my Macbook's sound are both set to the MixPre.
I have my Midi on the Macbook set on 2-channel 24 bit integer (44.1 kHz) for both input and output.
Do I need to fix something in my I/O?
Thanks for the help in advance!
Old 02-22-2018, 12:21 AM
Stig Eliassen's Avatar
Default Re: MixPre-3 as interface... but no mic?
Welcome to the community.
Maybe this video can help?
Old 02-22-2018, 01:54 AM
Thanks! I figured it out. I needed to change the analog in my I/O to support the correct channel.
Old 02-22-2018, 02:02 AM
That's great!
PT will not recognize my MIDI interface [SOLVED] JMUMRD MIDI 3 05-19-2015 04:17 AM
Sound Devices Mixpre-D BRH Third Party Interfaces 4 11-22-2013 10:07 AM
11R as interface...some issues I'd hope to get solved Oli P Eleven Rack 8 03-30-2013 04:34 PM
Using ProTools with No Interface [solved] noahbalboa Pro Tools 10 5 01-30-2013 09:11 PM
Bottle Neck - MixPre to AnalogMixer to 888 fifty8th1 Pro Tools TDM Systems (Mac) 0 10-04-2003 11:16 AM
