Old 02-13-2018, 05:52 PM
d02457219's Avatar
d02457219 d02457219 is offline
Default Any other way to set up Akai pads?
I have a weird issue. Trying to control EZ Drummer 2 with an Akai MPD218 pad. It is connected and set up in Midi Studio and selected in Input devices. All drivers for MPD218 software.
It works fine in PT10 but I cannot get it work at all in PT11 or 12. Is there some other setting that has to be set. I am not too versed on using this type of pad and I only use it to create drum patterns for EZ Drummer but I have been all over the internet and even contact Akai who said it should work in any version of DAW.They ran me through the set up for PT and it only works in PT10.
Does anyone have one of these that can help me through?
I use a Windows PC that is more than capable of running anything. This is the only piece of gear that I can't figure out to make it work in 11 & 12.
Thanks
Old 02-13-2018, 06:04 PM
amagras amagras is offline
Default Re: Any other way to set up Akai pads?
Subscribed, Akai pads are a real pita for me too.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-14-2018, 05:23 AM
Thanks
When you say you can't get it to work at all what do you mean? That it won't trigger sounds in EZD? Does EZD work at all in PT11 & 12? If not make sure that you have the aax64 format version of EZ Drummer installed. That it works okay in PT10 says that at least the MPD & EZD are communicating. Problem may be that PT10 is the last that uses RTAS format plugs; it does use aax32 format plugs as the aax format was introduced in PT10.
Jack
QAPLA!
I pads and V-pro sw rec Pro Tools 10 12 12-28-2012 08:21 AM
Something with pads Stig Eliassen Virtual Instruments 13 02-14-2011 02:09 AM
Transfuser pads mapped to axiom pro pads th3actor Virtual Instruments 0 09-02-2010 04:22 PM
C24 - no mic pads? rtcstudio Pro Tools TDM Systems (Mac) 13 01-22-2010 03:41 PM
Pads gg85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-27-2007 07:21 PM
