MC Mix and Totalmix
I cannot get any interaction between these two. MC Mix works fine with PT9 However, so far it has been a no go with Totalmix.
Here is what I have done. 1. Drag HDSP Mixer from applications folder to Eucon under Preferences in OSX 2. Set "Mackie Control" under protocol, MIDI ports 1-4 3. Close preferences and reboot computer. 4. Under HDSP "options" tab, open "preferences". 5. Set MIDI input to "Control Surface Euphonix Port 1" 6. Set MIDI output to "Control Surface Euphonix Port 1" 7. Under Mackie Control Options check "Enable Protocol Support", Full LC Display Support", and "Send Level Messages". Click "OK". 8. Lastly, under options tab, check "enable MIDI control". Nothing works. No help from RME. They tell me "its in the manual". Last edited by therecordinghouse; 08-10-2011 at 12:47 PM. Reason: spelling. |
Re: MC Mix and Totalmix
I have the same problem, the thing is that it worked fine with Eucon 2.5.7 and the RME 3.08.5 drivers.
I had a hard drive crash and after a complete re install with the latest drivers from RME (3.26) and Eucon 2.6 it stopped working. I have since gone back to the driver configuration that was working, and I can't get that to work either now. No help from RME. I am at a loss on what to do next.
PC-Windows10 64bit - i7-4920 - 32gb ram - RME9632 -Nuendo 8 - ProTools 9 - MC Control - Mix - Transport MAC- OSX - 10.10.5 - MOTU828MKII - ProTools9 |
Go to Library/scripts/Euphonix Scripts/Utils/cleanEuphonixSystem and run the script. Uninstall your current EuControl, then install 2.5.7. Reconfigure Mackie Control. All should work.
JC |
How do I do this on a PC? I cannot find the "script" you mention.
for what its worth, all is fine now with the latest eucon update 2.6.2.
MC Mix and Totalmix/babyface
Hi!
I have a dream this evening. It is to get my volume knob on the RME Babyface to move the Jogging Wheel on my Euphonix Controler instead. I've been fooling around and tried to connect via midi, completely without success. Anybody know where I should start? Kindly Stefan |
Macbook Pro 2gb of ram with RME Totalmix? | thepilgrimsdream | macOS | 1 | 06-21-2012 02:42 PM |
Artist Control for Stylus RMX and RME TOtalmix | 11miles | Artist Series | 4 | 04-03-2012 04:22 AM |
2.6.1 RME totalmix control still broken | johngar | Artist Series | 13 | 11-26-2011 11:13 AM |
Can't control RME TotalMix FX on Lion | DaveDaveDave | Artist Series | 3 | 10-27-2011 11:22 AM |
MC Control not controlling RME totalmix | johngar | Artist Series | 2 | 08-08-2011 07:13 AM |
