need to write a gradually fluctuating tempo map
Is there a way to make tempo changes that are gradual in PT? as in writing a tempo map to a classical music composition
eg: If I need to go from 80 bpm at bar one to 84 bpm at bar 10 can the tempo gradually accelerate between bar one and bar 10 (without having to meticulously program in incremental increases in tempo)? Digital Performer can do this. If PT can't, can a tempo map from DP that has gradual tempo changes be imported into PT? (I haven't had success with this but may be doing something wrong or have a software version comflict). Any info appreciated. |
Re: need to write a gradually fluctuating tempo ma
Out of luck if you own a Mix System!!!
You'll have to upgrade to HD for thousands so you can be able to set a Tempo Map?? I used to do this on an Atari now I'll need a Blown out HD system to do simple little MIDI things What a Scam!!! |
Write Tempo Change via Fader? | Logichead | ICON & C|24 | 0 | 05-05-2012 12:54 PM |
Gradually increasing click tempo | fifthflaw | Pro Tools TDM Systems (Mac) | 10 | 08-16-2011 11:00 PM |
Gradually Increase Tempo of a Phrase | goat1927 | Pro Tools M-Powered (Mac) | 0 | 02-17-2010 10:39 AM |
Need to gradually increase TEMPO | metrov | General Discussion | 6 | 03-26-2005 07:02 AM |
How do I gradually slow down the tempo? | underbiteman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-13-2004 01:31 PM |
