OT: Has anyone seen/fixed this type of distortion?
I was recording some audio into my laptop and I overmodulated the signal a handful of times. Instead of just lopping off the top of the waveform and and creating the normall "buzzy" digital distortion, I'm getting this horrible crackly distortion.
I took a look at the waveform and it seems that any peak that went over zero didn't just get cut off, but "looped over" to the lower swing of the wave form. It's hard to explain, but here's an image: http://www.morlando.com/images/distortion.jpg Has anyone encoutered this, and has anyone found any way to fix it (other than going in and redrawing each overmodulated peak). The algorithm to find and fix these errors seems like it should be pretty straightforward, but I'm no programmer. (I've tried some de-clickers without a minimal amount of success.) |
Re: OT: Has anyone seen/fixed this type of distortion?
B
U M P . |
Yikes!
Hey, how did you get that image of the waveform? and sorry, no ideas...
Ill suffer winter alone; ten thousand miles from home... |
You zoom in around 6 times, and you get so close you can pencil the waveform.
[TheLP] |
I just spent an hour penciling out a bunch of these things. It's not worth it. It'll take me days.
I guess I should pay more attention to where zero is. To answer the image question, I opened the file in an audio editor (Peak), zoomed in, and took screen grab. |
If the same part exists in another place on the track, copy and paste over the clipped section. For instance, if chorus 1 is clipped but chorus 2 is clean-paste chorus 2 in place of chorus 1. Remember if you are recording 24 bit, you can leave yourself some headroom without a serious compromise in S/N ratio. I don't know if you can re-draw that much error, but you can try.
Try Free Bomb Factory Essential Clip Remover.
http://www.digidesign.com/products/d...roduct_id=4201
RRP: Greatest Hits Vol 2 |
Metallic type of distortion on tracks w/003 | Jerry K. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-22-2014 06:54 PM |
intermittent distortion temporarily fixed by change to playback engine settings | tonyK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-11-2013 06:16 AM |
Audio suddenly changes to AM/FM type distortion. | beholder74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-30-2006 08:50 AM |
HELP ! ! PowerBook G4 error Type 3, Type 2 HELP ! ! | Liquidtrek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2002 06:28 PM |
PT Mix 4.3.2 +Midi Playlists = Type 2 & Type 1 crashes | Lewis Ross | Pro Tools TDM Systems (Mac) | 1 | 11-09-1999 07:03 PM |
