Old 11-14-2010, 01:36 PM
Kev79 Kev79 is offline
Default PT9 - 003 rack -ASIO DRIVER error with Cubase 4.5 - any solution?
I installed PT 9 on XP SP3 and it works great. however since I used/use Cubase 4.5 as well in the Studio I had trouble with the 003 rack asio driver. In Cubase when I play any recorded audio track it sound like a bit crusher - if I use VSTi's it sounds normal. I use the 003 as my main interface.
I had the same problem with the 8.0.4 update.
Going back to 8.0.3 solved the issue with the driver.
anyone else having this problem or a solution?
thanks
Kevin
kaleidoscope-studios.com
Old 11-14-2010, 02:10 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: PT9 - 003 rack -ASIO DRIVER error with Cubase 4.5 - any solution?
PT 9 is not supported on XP, Windows 7 and Snow Leopard only.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 11-14-2010, 02:24 PM
Default
PT 9 runs with XP SP3 on 2 computers without problems even if it is not officially supported - but my question was more regarding to the 003 rack driver.
The new asio driver that came with 8.0.4 and PT9 doesn't work correctly with Cubase 4.5 ... I was just searching for some help or experience from people with similar setup...
Old 11-14-2010, 05:23 PM
The Weed's Avatar
My point was that, although you may have it working, it may not work for everyone and that some or all functions may not work for some or all. The drivers being a case in point.
Cheers,
Old 11-15-2010, 01:24 AM
oxelamp oxelamp is offline
yea, pt9 has the same asio driver version for 002/003 as pt 8.04cs2.
and shares the same problems aswell.
still waiting for a solution. it's been few months now :P
[IMG] code is Off
002 rack keeps losing asio driver in cubase 4.5 nincompoop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-18-2009 05:52 AM
keep losing the asio driver for digi rack 002 in cubase 4.5 nincompoop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-15-2009 07:03 AM
Mbox 2 Pro & Cubase SX3 (Asio driver error) Metroid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2009 07:37 AM
The ASIO Driver Solution!!!! Reason, RealOne, _Dova_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-09-2003 11:37 AM
Cubase SX and Asio driver under PT 5.3.1 mucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-29-2003 08:24 AM
