Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-17-2020, 02:38 PM
BiggDogg BiggDogg is offline
Default Latency between mouse and ProTools2020
I recently upgraded to ProTools2020 from 12.7.1. It has been working very well for about 4 weeks.
Suddenly there is a latency between my Blue Tooth mouse and PT. This has never happened before in 2020 or any previous versions. There is now a about a 2-3+second delay from the time I click on a clip before it will allow we delete it. Another example is when I use the trimmer to trim a MIDI note after I click on the MIDI note where I want it trimmed there is a delay of several seconds and, sometimes the note is trimmed much more than I requested or not at all.
My system: Windows10, i7 processor 16G RAM, Dell laptop 3780, Focusrite 6i6 interface
I've noticed that other people have had this issue in the past with earlier versions but in the forum there is no real fix offered, just guesses and no one from Avid responded. Has anyone else had this problem and, if so, what did you do to fix it? Why would everything be working perfectly and then suddenly it doesn't?
Old 09-17-2020, 02:48 PM
capt kirk capt kirk is offline
Default Re: Latency between mouse and ProTools2020
Some times you hit key sequences which cause **** to happen, inadvertently, and you cant figure out why.......some parameter got tweaked, or driver got changed, gawd only knows....
www.kfaudio.ca
Old 09-17-2020, 03:42 PM
sw rec sw rec is offline
Why I don’t run a wireless mouse or keyboard. Just not reliable enough.
Old 09-17-2020, 03:59 PM
Ive run the magic mouse and keyboard and they work incredibly well, but they eat batteries.........gotta get the new one
www.kfaudio.ca
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
Any latency in wireless Key Board/Mouse vs Wired? rockguitarist1255 Tips & Tricks 9 04-15-2013 10:23 AM
Trackball Mouse with Normal Mouse Operation dstryrwiz Windows 0 05-27-2011 11:30 AM
PTLE8cs3, Mouse Movement, Triggers Big DPC Latency Greg M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-28-2009 08:22 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
