Issue With Automation in CPTK 2 - Capture and PReview
Any thoughts on this ? ...
I am on a Mac Pro 2.4. Westmere 8 core running Pro Tools 9.02 I am trying to drop in the capture automation from one channel to another track ... When i Write to it ... it only puts the nodes in but not the actual automation on the other track ..However doing this on the same track works as it should ? Is this a bug or something ..or does anyone else have this problem ? thanks |
Re: Issue With Automation in CPTK 2 - Capture and PReview
Kind of hard to follow what you're doing, but Preview and Capture (as far as I understand them) aren't meant to copy automation between tracks.
You could drag a region from one track to another (with automation follows edit on), and that would copy common automation from one track to another. Or duplicate the track, etc.. |
Preview/Capture-Need Advice | icenet | Tips & Tricks | 12 | 12-14-2012 06:32 AM |
Issue With Automation in CPTK 2 - Capture and PReview | hwill2008 | macOS | 3 | 05-04-2011 03:18 AM |
Preview/capture Automation MC Control | SBP | Artist Series | 15 | 04-20-2011 01:52 PM |
anyway to access Preview and Automation preview on PC or Edit | vudoo | ProControl, Control|24, Command|8 | 1 | 09-12-2009 06:49 AM |
Preview and Capture differences | macaholic | ICON & C|24 | 2 | 05-20-2009 12:55 PM |
