Old 11-26-2004, 12:40 PM
PHead14006 PHead14006 is offline
Default 882/20 with 96 i/o legacy
I have a new 96 i/o and I hooked up my old 882/20 to the 'legacy' port. The Hardware Setup recognizes it and I can use the "identify" function. The ch 1-2 digi-analog toggle works as well. All sync cables are correctly installed. I can not get any inputs to be heard in Pro Tools. Haven't had time or need to test 100% yet, so stupid oversight a distinct possibility. Any thoughts?
G4 800 512mB RAM, Pro Tools 6.4, Command 8, 96i/o, Sync i/o
email [email protected]
I Keep A Vigil In A Wilderness of Mirrors (Fish)
Old 11-26-2004, 05:44 PM
CCash CCash is offline
Default Re: 882/20 with 96 i/o legacy
Have you assigned ins and outs in the I/O setup? Your 96 will typically have the first 8 ins and outs, and the legacy interface will take the next 8.
Old 11-27-2004, 08:06 AM
Yes. The default assigns the 96i/o 16 inputs but I deleted the last 8 and assigned them to the 882. The 882 is definitely recognized but no audio passes in the inputs. I have not tried to use the outputs yet, as I have no need, but will continue to troubleshoot. Also, I have made sure I am using only 16bit sessions when attempting to use the 882. Also it is worth mentioning that the 882 occasionally goes randomly into 'identify' mode with all lights on even though I am not using it.
Old 11-27-2004, 01:01 PM
I only bring this up because it's an easy mistake -- the legacy interfaces don't show input level on the front-panel meters, only output. Make sure you're checking for level on a record-enabled track or aux with inputs 9-16 assigned.
According the answerbase, you also have to be using Superclock:
http://answerbase.digidesign.com/detail.cfm?DID=27034
Legacy??? suicune Pro Tools TDM Systems (Mac) 81 04-03-2013 05:12 PM
Legacy 888 with HD I/O James Drake Pro Tools TDM Systems (Mac) 2 05-24-2012 11:37 AM
PT8 and Legacy RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-13-2008 05:37 PM
Legacy 888 and ADC Nicolasixxx Pro Tools TDM Systems (Mac) 6 06-18-2006 06:59 AM
PT 6.0 on legacy Mac? tubajay Pro Tools TDM Systems (Mac) 3 02-25-2003 04:16 PM
