Old 04-24-2004, 09:20 PM
PHead14006 PHead14006 is offline
Default can\'t zoom in to sample rez
PT 5.1.1/24Mix+/G4 800/512
Suddenly unable to zoom in to sample resolution on waveforms enabling pencil tool. Tried all known zooming methods.
I Keep A Vigil In A Wilderness of Mirrors (Fish)
Old 04-24-2004, 11:03 PM
Default Re: can\'t zoom in to sample rez
Are these files imported from OMF? Consolidate the area you want to use the pencil on first.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-24-2004, 11:50 PM
DigiTechSupt's Avatar
You may also want to check the following.
-When the Edit Window Default Length is set too large, it is not possible to zoom down to sample level.
-The Edit Window Default Length field can be found in the Setups>Preferences>Display window.
If there are any automation points in a visible track past the maximum Pro Tools session length (about 12.5 hrs @ 44.1k, and 12 hrs @ 48k) Pro Tools will not zoom past quarter frame accuracy. This also occurs if the cursor has been dropped past the session length limit.
Hiding the offending track(s) or deleting all automation points past these session length limits will eliminate the problem.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Can't zoom in to sample level! What happened? EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-08-2011 07:42 AM
Can't Zoom in to Sample Level guitarmongoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-26-2008 09:06 PM
zoom to sample level bug Steve MacMillan Pro Tools TDM Systems (Mac) 21 01-10-2008 09:02 AM
Can't Zoom to Sample Martin Vipond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-09-2004 06:07 PM
Zoomer won't zoom to sample level Robert U 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-06-2002 07:19 AM
