Old 10-31-2011, 09:02 AM
Default How to use X-Key on clip gain?
before PT10 I sused the X-key all the time to smoothen hard volume-curves to ramped types. This doesn´t work on clip-gain-curves anymore because X will cut the clip itself.
Insteas one seems to have to grab and drag the breakpoints around.
Is there an alternative shot-cut that would do the same on clip-gain curves like it works with volume curves?
For me the short-cut is faster than grabbing the break-points like a brain surgeon.
thanks,
frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 10-31-2011, 09:29 AM
dieffe dieffe is offline
Default Re: How to use X-Key on clip gain?
Yes, Control+Shift+X !!!
BTW, love clip gain!
Davide
Old 10-31-2011, 12:18 PM
Max H. Max H. is offline
good to know. also you can view the clip gain line quickly by hitting ctrl+shift+"-" on a mac.
is it possible to change the clip gain of more than one clip at a time?
shift and opt+shift don't seem to do it.
Old 10-31-2011, 12:33 PM
Yes. Select all the clips, than CONTROL+SHIFT+ UP ARROW or DOWN ARROW to raise or lower the level.
I think that even the scroll wheel works, but I don't have a mouse to try this.
Overall, I'm really impressed with the clip gain implementation: it took a lot of time, but works really well.
And I find PT10 much snappier and stable than 9 or 8.
Davide
Old 11-01-2011, 12:58 AM
JWalkerPostAudio JWalkerPostAudio is offline
Cntrl+shift+scroll wheel is the way to go. You will go through undo levels like crazy though so be aware of that before attempting it, i.e. an adjustment of +/-16dB will cost you all 32 undos if the .5dB increment is your default.
-Justin
IMDB
Old 11-01-2011, 03:27 AM
Davide
thank you!
Old 11-01-2011, 11:14 AM
sounddroid sounddroid is offline
It's worth pointing out that when using the Selector tool, the cntl-shift-arrow/scroll nudging works on both whole regions and partial regions - if you just select a portion of a region (or portions of regions) it will create breakpoints and a "shelf" in the Clip Gain line.
Also, another great thing is being able to apply gain changes to multiple non-contiguous regions using the object grabber!
--Will Files
HTML code is On
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip gain??? calle.vs Post - Surround - Video 10 02-15-2009 03:02 PM
