High pitched noise while recording
I just started recording using a Roland Fantom X7 with my MBOX. I use Monstor keyboard cables so I think the cables are not an issue. I get a high pitched noise while I record & it in fact comes through when I play it back. Has anyone run into this ot have any ideas?
Thanks |
Re: High pitched noise while recording
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Tom wrote this
Have you read this, from the general troubleshooting thread? If you're experiencing noise from the Mbox II, there are several things to try: - Make sure you're using balanced cables on all balanced inputs and outputs. Remember that the Mbox 2 outputs are unbalanced, and should use unbalanced connections. - Try using a power conditioner for all your electronic gear (Furman, Monster). - Run your outputs directly to shielded monitors and not through a mixer to see if the noise goes away. - Some noise complaints arise from noisy power supply units inside computers - try installing and running on another computer (or if you're using a laptop, unplug the power supply and run off of batteries to see if noise goes away). Moving the Mbox II in relation to your monitor, computer or speakers may also lessen the noise. - Unplug and turn off all unnecessary gear and run only the computer, the Mbox II, and monitors. - Listen through headphones to determine if the noise is isolated to a particular output. - Make sure you're not running through a USB hub or other device - the Mbox II always needs to be plugged directly into the computer. - Try all USB ports on the computer to see if the noise lessens. - Trace your cable path for long cable runs, and isolate your cables from possible interference (other gear, florescent lighting, CRT monitors, etc). |
Thanks for the responses. Turns out that I was using unbalanced cables from my keyboard to the MBOX 2. Replacing them with balanced cables got rid of the noise.
Bob |
high-pitched noise from psu | dave192 | Pro Tools M-Powered (Win) | 1 | 09-11-2010 04:43 PM |
High-Pitched Noise when in PT | EnxStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-02-2008 07:20 AM |
High pitched noise from Mbox2 - what gives? | djmoss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-02-2008 01:32 AM |
High pitched noise from Mac via Mbox2 | djmoss | Pro Tools TDM Systems (Mac) | 3 | 05-01-2008 07:55 PM |
High pitched noise with plugins | lowoctave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-05-2006 09:01 PM |
