Re: HDX on MacPro5.1 Westmere,Xeon W3690, PT12.8.3 HD?
This thread is very interesting! I'm running two PT10HD rigs on 4,1 8-core 2.93 MacPros. This is the first that I've heard about upgrading the processor and firmware to 5,1 specs. But I'd like to ask - can an upgraded 4,1>5,1 run the latest PT12.8HD? I'm unclear because Avid system requirements for Mac say i7 processor is needed. On the other hand I see the two 5,1 MacPro's listed as supported - these are Xeon processors. I guess I don't get it... If an upgrade will let me run 12.8 (with an HDX card) that would be amazing! |
See my sig for my system specs. I'm running PT 2018.4 HDX and it's screams.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
I'm also reading up on delidding. I'm interested to know - why does the new chip need to be delidded? Is it because it won't fit with the heat sink? |
In either case you'll want Xeon 3.46 X5690's to get the fastest processors that will work in these Mac Pros. Yes, that ebay listing is what you want.
If you have the 1066mhz ram you should also upgrade to 6 sticks of 1333mhz with those upgraded CPUs. There are lots of Youtube videos showing the CPU upgrades. Also, a "before/after" Geekbench 4 test will give you and idea of how much processing power you gained. Most likely would go from a score of 14000 to 23000. |
Mid 2012 MacPro5.1 6core 3.33 for PT12 ? | SD70 | Pro Tools 12 | 2 | 05-21-2018 04:04 AM |
Hp dual xeon cpu with pt12 | JSOM | Pro Tools 12 | 4 | 02-10-2017 01:02 PM |
Mac Pro Westmere Mid 2010 | drums77 | Pro Tools HDX & HD Native Systems (Mac) | 17 | 08-28-2016 10:59 AM |
6 or 12 core Westmere for HDX and PT12? | wilkinswp | Pro Tools HDX & HD Native Systems (Mac) | 5 | 08-14-2016 07:16 PM |
Anyone using a Westmere Mac Pro...? | Jon_Atkinson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-10-2010 07:10 AM |
