#791
Re: AAE error -9173 stronger than ever on PT 12.5
As other already stated here, from my part, I have found a PLAN B SOLUTION :
PT is playback smoothly, without any spikes at all, when ALL THE PROTOOLS WINDOWS are reduced. I've looked at the CPU usage and the spikes are gone. I can EQ like that with the EQ window really easily. So it doesn't seem to be related to any third party plugins to me. It seems to be a graphical problems !!! Perhaps if we reduce a bit the amount of informations in PT edit windows (since the mix windows is slightly less buggy) it'll help ? Anyway, I'm pretty happy to discovered this, since it's the first time that I've found something that looks like a potential solution for printing my tracks without any hassle. |
#792
Re: The ole 9173 error stronger than ever on PT 12.5
Turning my wifi off just worked for me! Thanks, guys!
#793
If you're on Windows, see if there is anything in this thread - especially about the graphic card drivers - that might help.
#794
I'm on Mac unfortunately :s
#795
Btw - I'm a Windows 10 user. |
#796
I just tried something out and the results were quite illuminating:
I opened up a complete mix session, one rife with 9173 errors throughout (it was a beast to finish btw). On it I have several bus layers, including those for instrument groups and separate mix and master busses, funneling to an audio print track. Without removing any plugins or tracks of any kind, I started simply removing any pathways to the Monitor Out one level at a time, starting with the print tack. No reduction in errors. Then the master buss. SIGNIFICANT reduction in errors. Then the mix buss. NO ERRORS AT ALL. Mind you all the plugs are sill engaged and cooking - just the number of bus layers are being reduced. So at that point I decided to fire up a whole bunch of extra plugs to see how far I could take the CPU before getting 9173's again. The answer is somewhere between 85-95% - and THAT number sounds closer to right. (it's been crapping out at @ 65% for me otherwise) Also - to make sure this wasn't just due to the lack of audio being passed through the now "unused" busses, I went ahead and picked out a few tracks and routed them to the disconnected busses directly. Results stayed the same. Checked it with both the normal and dynamic plugin processing engine. Results stayed the same. Anyone here try this already? As a reminder, I am on a Windows 10 system, so I don't know if this would be relevant to you Mac guys or not, but I am curious. Last edited by wonder6oy; 09-30-2017 at 09:01 PM. |
#797
So check it out:
I can totally reproduce this error on my system with NO audio and NO 3rd party plugs. Just Dverb and Signal Generator with a (heavily) multilayered bus structure. Here's the session... https://www.dropbox.com/s/b0aeqllulq...0test.zip?dl=0 My CPU usage has to be at least 65% to see the magic happen, so if you want to try it for yourself and have a monster system, just pile 'em on till you get a dropout. Curious to see if anyone else has the same results. And please MUTE YOUR VOLUME. It shouldn't blow anybody's speakers out, but it potentially could! |
#798
With a session with DVERB blowing CPU your first response should be to check for denormalization problems. Start throwing dither plugins in front of DVERB. This has been posted about many (thousands?) of times on DUC before. You should search and find past explanations of what denormalization is. Unclear why Avid does not bother to mitigate this in the plugins that suffer from it.
Sent from my iPad using Tapatalk |
#799
Which other plugins have you found to be sensitive to denormalization?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#800
Do you know how I can tell you have not spent time searching for your answer before posting this question?
The classic denormalization plugin is Sansamp, followed by DVERB. But for all the plugins out there... who knows, if you see this behavior you start looking for it with Avid or third party plugins. Sent from my iPad using Tapatalk |
-9173 error in PT 12 | ArKay99 | Pro Tools 12 | 10 | 06-11-2016 01:41 AM |
Error AAE 9173! Urghhh!!! | Voice Crafters | Pro Tools 11 | 9 | 06-12-2015 12:28 PM |
Error -9173 | music.m | Pro Tools 11 | 1 | 03-19-2015 09:42 AM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
