Old 08-30-2002, 09:44 PM
PRS4LIFE PRS4LIFE is offline
Default What are everyones PlugIns used on the Master Fader?
Mine is....(in order)
Digidesign 4 band-EQ
Waves C1 Compressor
Maxim
Waves L1 Ultramaximizer
iMac 20" 2.4Ghz Intel Core 2 Duo, 4GB 667 Mhz DDR2 SDRAM, Guitar Rig Session I/O, M-Audio Axiom25, Pro Tools 10.1.3, Mackie Mr8mkII Monitors
Old 08-31-2002, 12:21 AM
keny keny is offline
Default Re: What are everyones PlugIns used on the Master Fader?
PAZ
Rennaissaince eq (if necescary)
C4 (sometimes)
L1+ (usually)
p.s. I submix drums and compress them seperately.
just to toot my own horn, I am in the process of relocating to Los Angeles and lookign for a job, so if anybody knows someone who can help me get established as an audio engineer and producer, check out my creds at http://www.kenyruyter.com and call me 310-909-9115
myspace page
Old 08-31-2002, 01:55 AM
Bloux Bloux is offline
Waves C1 Compressor
Maxim
<font size="2" face="Verdana, Arial">why the maxim and the ultramaximizer? I thought the ultra is a beter maximizer than the maxim.
why use both? [img]images/icons/confused.gif[/img]
Old 08-31-2002, 02:09 AM
vonbleak101 vonbleak101 is offline
Yeah thats pretty full on!
Any way i use the Waves renaisonce Compressor
and the waves renaisonce 4 band eq
PS: I use the Waves ultramaximiser when mastering in soundforge. [img]images/icons/grin.gif[/img]
Audio Engineer/Musician/Producer
Old 08-31-2002, 02:13 AM
Roy Howell Roy Howell is offline
C4 sometimes, but as little else as possible...
rh music
Old 08-31-2002, 04:00 AM
Dr.John Dr.John is offline
C4, then Maxim. Thats it.
Dr.John
Don't cut that! You never know what it might be connected to...
Old 08-31-2002, 05:22 AM
SKI SKI is offline
I see people I'm around using this combo
Q10
C1(or REN Comp)
L1
Maybe I'm different from most but I prefer not to load the master fader.
This is probably where the strength in the PC platform comes through, since I'm more comfortable working on the mix than the master the high plug-in count works well.
I like to use the Bomb Factory compressors on individual tracks and not compress the master and use Maxim, AudioTrack or L1 on the master (it's usually Maxim) then use the L1 in WaveLab.
I also have a tendency to open the PT wav file in other programs to be able to use plugs that may not be available to the Digi on PC yet or that I already own on VST or Direct-X.
Keep in mind the L1 likes to be last, go for sound then volume, and also what works for you depends on the type of music you are doing.
URBAN MUSIC-
(Hip Hop and R&B)
Old 08-31-2002, 06:09 PM
The Weed's Avatar
The Weed The Weed is offline
I'm just doing voice over, no music mixing, but I thought I'd include my favourites:
Ren DeEsser - sometimes
Linear Phase EQ
Linear Phase Multiband
L2
I'm using a Rode NTK microphone and combined with the above I get a very full, warm sound that is crisp and clear.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-31-2002, 07:40 PM
mfym mfym is offline
Digidesign 4-Band
Digidesign Compressor
Digidesign Limiter
and leave the last spot empty for Dither.
Old 08-31-2002, 08:27 PM
marcusb marcusb is offline
For me on most mixdown sessions I only have a Bomb Factory Fairchild compressor across the mix bus. Preferably this would be an Al Smart C2 as a hardware insert across the mix [img]images/icons/smile.gif[/img] I occasionally stick PAZ in the last slot to get some calibrated metering and to see what's going on spectrally.
PRS: why use Maxim AND the L1 ? I sure hope you are at least swiching the dither off on Maxim [img]images/icons/smile.gif[/img]
Also guys remember if you are doing master fades in the session with automation the plugins are PRE-FADER, meaning as you fade out you are altering the way your compression/limiting is functioning (effectively raising the threshold) which can lead to some very odd results.
Cheers,
Marcus
DSP Plugins on Master Fader are being repurposed as Native Mixchump Pro Tools HDX & HD Native Systems (Mac) 2 12-16-2012 07:47 AM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 12:02 PM
major issues with master fader plugins and PT satchvai Tips & Tricks 4 04-05-2006 06:57 PM
How do I get more than 5 plugins on Master Fader? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-13-2004 01:05 PM
plugins on master fader... dmaxj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-08-2003 07:43 AM
