Old 12-10-2014, 11:23 PM
BrianJArmstrong BrianJArmstrong is offline
Default Surround to Stereo Monitoring (Neyrinck alternative)
Hello,
I'm a PT10 + CPTK > PT11HD convert and I have some 5.1 tracks on my system that I'd like to monitor in stereo headphones.
Before I could slap on the Neyrinck plug in which was included in CPTK, but now is no longer a part of the deal. I don't immediately see an alternative included with PT11HD.
Please tell me I'm overlooking something. Don't really want to split into mono and adjust volume/pan to compensate.
Thanks.
Brian
MacBook Pro: Retina, 15", Mid 2014
Processor: 2.5 GHz Intel Core i7
Memory: 16GB 1600 MHz DDR3
OS: 10.12.5
PT: 12.8 HD - no interface. headphones and ilok.
Old 12-10-2014, 11:49 PM
EarHole EarHole is offline
Default Re: Surround to Stereo Monitoring (Neyrinck alternative)
My System has a digi down mix plugin.
Old 12-10-2014, 11:52 PM
under multi-channel or multi mono plug-in?
edit: nevermind... problem is I can't put it on a master fader. Makes sense. Thank you!!
OS: 10.12.5
Old 12-11-2014, 12:32 AM
mr.armadillo mr.armadillo is offline
You can also simply double buss and build a "downmix plugin" yourself with adjustable mono busses. That being said, the Neyrink Soundcode LtRt is pretty cool and well worth it's money. It also features a ProLogicIIx decoder if you ever need one.
Old 12-11-2014, 08:05 AM
Spanner from Maggot Systems works well.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 12-11-2014, 11:33 AM
seanmccoy seanmccoy is offline
Glad you mentioned that! Not to hijack the thread, but I just had to deliver my first set of stereo stems from a 5.1 mix, and it's not clear to me why I can't put the Downmixer plug on the 5.1 Master Fader. My groups pass through 5.1 busses before going to the output so I can do the downmix there, but the output file is still six channels and I have to then convert that to stereo. Do I need to run all these busses through yet another 5.1 aux before the master fader?
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.6, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Quad; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.6, Apogee Rosetta 800, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Sierra, MOTU LP32, Pro Tools 2018.3
Old 12-11-2014, 11:37 AM
This 5.1 aux will BE your "master fader". You will feed your re-recording tracks from there.
Old 12-11-2014, 11:48 AM
Sure, that makes sense, and would eliminate any restrictions on stereo monitoring and file output. This project was literally my first PTHD gig, which I inherited mid-mix. Lots of stereo projects since then, but unfortunately no surround work.
Old 12-11-2014, 04:08 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
You can insert a Spanner at any stage and get a down mix tailored to whatever monitoring setup you have... even on a master fader.
the difference is that on a master fader you can't change the output format so you'd insert the 5.1 Spanner and call up a stereo down mix preset.
the result would be a 5.1 output with the signal on just the L and R.
you can then record that stereo subpath or arrange your monitoring to hear it.
give it a spin - 30 day full featured demo @ www.maggot.co.nz
justin
Old 12-11-2014, 04:11 PM
justin
Alas! No Windows version, or I'd own it already!
HTML code is On
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer Ale Pro Tools 10 3 08-14-2012 09:05 AM
Surround Mixing / Stereo monitoring with Soundcode Stereo Meads Post - Surround - Video 6 01-04-2011 04:52 AM
X-Form, Neyrinck, Surround lug....where? L-Dogg Pro Tools 9 12 11-29-2010 03:58 PM
Neyrinck surround plug Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-07-2008 08:49 AM
Neyrinck DTS Surround plug in Tim Hartnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-29-2006 01:22 PM
