Old 01-04-2013, 12:49 AM
Mark Ziebarth Mark Ziebarth is offline
Default Bus system corrupt?
in the last months I had the following problem occasionally:
It seems like the busses don't transmit any audio. In my normal session setup I sum everything to a «Mix bus» (in my case it's bus 31-32) and use subgroups if the session is bigger.
If I route the output of a track directly to an output I can hear it but not in the bus system. The only thing that helps is to quit Pro Tools and restart.
Is there any other cure? I am using PT 9.05.
Anyone?
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
Old 01-04-2013, 03:22 AM
peterle peterle is offline
Default Re: Bus system corrupt?
..repairing permissions and disk may help , i had similar symptoms
due to a damaged hd..
and of course delete preferences.
regards
foley artist , soundeditor
Old 01-04-2013, 10:48 PM
JFreak's Avatar
JFreak JFreak is online now
As I recall, this is a known bug.
Easy solution would be to upgrade to PT10 but it costs money. Try some other PT9 version to see if the bug is not present. Or keep restarting PT -- or try another buss
Janne
Old 01-05-2013, 04:00 AM
Thanks Jfreak,
that should be the reason to install PT 10. I have a copy already.
Best
Mark
Old 01-05-2013, 04:01 AM
Thanks Jfreak,
That should be the reason to install PT 10. I have a copy already.
Best
Mark
corrupt 8 LE dvd konjawitten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-07-2012 07:54 AM
Corrupt Sessions ichbin Pro Tools TDM Systems (Mac) 9 11-29-2009 10:56 PM
System Drive corrupt - Can't upgrade to OS X 10.4 Sound-Influence Pro Tools TDM Systems (Mac) 8 02-01-2006 07:47 PM
Corrupt Playback hdace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-11-2003 08:01 AM
plug in corrupt? tandem Tips & Tricks 1 03-02-2003 04:08 AM
